Question about Xerox 700 Digital Color Press ITB Transfer Belt - Special Order Item
127-211 CODE ERROR
When the printer is running affter 50 sheets mark this code
Canon CLC 1000 error code E075 - 0004 please help me get rid of it
[Phenomenon]
Error code E075
[Cause]
Because of the factors listed below, some problems may occur in the controls to prevent the transfer belt
shifting to one side due to malfunctions of the swing motor assembly and in such a case error code E075 gets
displayed.
1) Sliding fault of the part A in the Fig.1
2) Deformation of the sheet metal of the swing motor assembly
[Factory measures]
1) The resinous material has been added, as shown in the Fig. 2, to improve sliding.
2) The reinforcing sheet metal has been added, as shown in the Fig. 2, to prevent deformation of the sheet
metal of the swing motor assembly.
When the error code E075 gets displayed, run checks as described in the Service Bulletin CLC1000-005
(CAUSE OF PROBLEMS BROUGHT ABOUT BY ERRORS OF THE TRANSFER BELT
MECHANISM). If the error code E075 still gets displayed even after running the checks, replace the old
swing motor assembly with the new type by, following the instructions on removing the transfer belt swing
motor assembly described on page 4-50 of the Service Manual.
Affected machines
NFH01171 and later
PFH00044 and later
QFH00129 and later
RFH00079 and later
SFH00221 and later
TFH00127 and later
UFH00657 and later
Jun 11, 2010 | Canon CLC 1000 Color Copier
Admission to a professional course is subject to the following condition: a) Marks in mathematics > = 60 b) Marks in Physics > = 50 c) Marks in Chemistry > = 40 d) Total in all three subjects >...
So:
X >= 60
Y >= 50
Z >= 40
Take 51 sheets of "graph-paper" (1+200 minus 60 minus 50 minus 40).
On the first sheet of paper, label the graph-title as 'Z=40'.
Label the X-axis from 60 to 200.
Label the Y-axis from 50 to 200.
Draw a straight line from (X=60 and Y=(200-60-40))
to (Y=50 and X=(200-50-40)).
On the second sheet of paper, label the graph-title as 'Z=41'.
Draw a straight line from (X=60 and Y=(200-60-41))
to (Y=50 and X=(200-50-41)).
On the next sheet of paper, label the graph-title as 'Z=42'.
Draw a straight line from (X=60 and Y=(200-60-42))
to (Y=50 and X=(200-50-42)).
On the second sheet of paper, label the graph-title as 'Z=43'.
Draw a straight line from (X=60 and Y=(200-60-43))
to (Y=50 and X=(200-50-43).
Keep going for all 51 sheets of graph-paper.
Stack the 51 sheets on top of each other,
to visualize the "3-D" solution to the problem.
P.S. Don't tell your school-teacher that I helped you do your "homework".
Nov 04, 2009 | Microsoft Computers & Internet
Affter adding developer to my konica 2223, How do I reset the machine. (to clear ''routine service req'' on the display.
turn the machine off hold down 4 and 7 key turn on enter 9 0 then the date power off then on while holding 47 again and press 5 1 and start if you dont run the 5 1 you will get an error code and not be able to use the machine
Sep 29, 2009 | Konica Minolta Office Equipment & Supplies
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
I have a MFC-665CW error code 51 unable to clean
change your cartridge insert new cartridge then solve it please send me reply
Jun 26, 2009 | Brother MFC 420CN All-In-One InkJet...
Error 6502 PIXMA iX 4000 with CISS
Ok there
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
All Best: Pineworks
Jan 07, 2009 | OEM Systems PIXMA iP3300 Photo Printer
Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Big black marks down the center of every sheet?
REPLACE THE PHOTOCONDUCTER DRUM OR CLEANINGBLADE ASSY MOST LIKELEY JUST NEEDS NEW CLEANING BLADE
Jan 04, 2008 | Dell 3100cn Laser Printer
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Xerox 700 Digital Color Press ITB Transfer Belt - Special Order Item Logo
505 people viewed this question
Top Xerox Home Experts
Donni Steen
Tom Chichester
Are you a Xerox Home Expert? Answer questions, earn points and help others
