BEC split AC shows E4 error.Why ? what is the solution for that ?
SOURCE: Ramsond split AC 12000
HI YOUR BROBLEM I THINK IS THE SENSOR FOR THE ROOM TEMP
Posted on Dec 05, 2008
SOURCE: SPLIT AC
PROBLEM WITH THE INSIDE FAN MOTOR
Posted on Feb 25, 2009
  • 16 Answers
SOURCE: E4 Error in Hunday Split Ac
where are you located , like if your residing in noida UP then u would face the issue due to polluted air , and the dirty and harzadeous gasses comming out from back water river, next time when technicians come , kindly ask them for proper flushing and testing it by nitrogen pressure. there can be a minute leakgae.
Posted on Mar 19, 2010
  • 14 Answers
SOURCE: OUR WAVES SPLIT AC DISPLYS
1? Check whether the winding resistance and operation current of the compressor are normal. 2?Check whether the high and low pressure is normal when the unit is running. 3?Check (whether the coil pipe sensor is normal) whether the contact of the inserter on the circuit board is well, the coil pipe temperature sensor is fixed, the evaporation of the indoor unit is well, the key is to check the evaporator temperature detected by the coil pipe temperature sensor has reached the cooling or heating temperature. 4?Check whether the surface of the condenser is too dirty, it should be cleaned when it is too dirty. 5?Check whether the capacitance of the outdoor motor and the fan is damaged, it should be replaced when
Posted on Aug 22, 2011
SOURCE: e4 in an innovair a/c
Check the Capacitor.
Posted on Oct 06, 2011
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Error e4 sir air split unit
We have a SirAir Split unit Airconditioner, It's not cooling and shows e4 error.
Feb 27, 2013 | Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
Your technicians are not properly locating the source of leak and repairing it before adding more refrigerant. Have them use a leak detector(sniffer) or colored dye that will reveal the leak. Then repair and fill to specs.
A refill of a slow leak will work until refrigerant it leaks out again.
Sep 02, 2017 | Heating & Cooling
Mar 19, 2010 | Heating & Cooling
E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
May 07, 2009 | Heating & Cooling
SPLIT AC
Sep 27, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Sep 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
