Question about Janome Memory Craft 9500 Computerized Sewing Machine
The default straight stitch on my MC 9500 is 3.5 and 2.0. I can change the setting and sew with the stitch I want. However, when I stop it reverts back to the default and I have to reset it.
I would like to change the default setting to 3.5 and 3.5 or have information to correct the problem of resetting to the default before turning the machine off.
    Top Expert:
  • Janome Master
  • 42,103 Answers
Talk with a sewing shop as I feel that there should be a save setting button to achieve this
Posted on May 03, 2015
Straight stiches great. select any other stitch and it stitches about an inch and then stops
Test: With straight stitch and needle on left side sew.
With straight stitch and needle on right side sew.
Does one of the two sew and the other not sew?
The reason is the timing of the needle and bobbin are not set right. In other words it is in need of timing from a repairman.
Dec 12, 2015 | Singer 8763 Curvy
What is the setting for regular straight stitching?
Stitch length @ 2.5mm (between 2 and 3 on the scale).
Stitch width @ zero.
Top selector lever @ 1 / 2 or (1 slash 2).
Needle position @ center.
That's it, no rocket science here. Stitch length will vary per application and per user choice. The 2.5 setting is only a suggested default.
Sep 22, 2015 | Bernina 1008
How do you change the default stitch length for the straight stitch.
A setting change while you are sewing should not happen. Sounds like you will have to take your machine in for service.
Apr 11, 2015 | Janome Memory Craft 9000 Computerized...
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Babylock denim pro
I'm not sure what you've actually got, since your question mentions two different machines. Straight stitch is typically the default setting (the thing that comes up automatically) on computerized or electronic machines. On other machines, there may be an indicator for straight stitch (often stitch 0 or 1 if numbered), or it may be a zigzag stitch of width 0, length whatever.
Jan 25, 2014 | White Sewing 1418 Mechanical Sewing...
How do I oil my janome MC 9500 sewing machine
You can never used oil to any MC machine. it will damaged the sensore of your machine.If possible just open head cover and clean broken thread from the movable part.
May 10, 2012 | Janome Memory Craft 9500 Computerized...
New Singer Futura machine stops & tries to revert to overlock.
Sorry to say but it sounds to me that you need to take your machine in to be checked.
Mar 05, 2009 | Singer CE-200 Quantum Futura Computerized...
Sewing Machine Stops
this sounds like its set for zippers check settings!
Dec 09, 2008 | Husqvarna Sewing Machines
Sewing machine straight stitch is not straight
It sounds like it is making a blind stitch, does it look something like this? -----v-----v-----v-----v-----v If so it might be on the blind stitch setting instead of the straight stitch! ;-)
Oct 11, 2007 | Sewing Machines
Janome Memory Craft 9500 Computerized Sewing Machine Logo
51 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
