The front wheel has come off of the truck. The wheel & the metal rod that attaches the wheel to the body seem fine. Problem appears to be with the body. Did we lose a part in the collision that I can replace or did we snap off part of the plastic body? Any advice on how to repair/replace/fix this truck to get it rolling again?
SOURCE: Little Tikes Cozy Coupe red plastic wheel caps
The caps are a type of "acorn nut". Check a local hardware store (not the big guys) for this type of fastener and bring the shaft with you to get the correct size. These should not cost more than about $.50 each.
Dan
SOURCE: little tikes cozy coupe
Try replacing the screw. If you cant, get a long thin bolt and nut to replace it.
SOURCE: Our 2yr old grandson was
This link:
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=2485&
shows which replacement parts are available from Little Tikes, and I don't see the one you're looking for. I tried to call their Consumer Services line at 1-800-321-0183, but they're open M-F from 8 am to 8 pm and Sat 9 am to 2 pm, EST. Please give them a call tomorrow.
An alternative might be to take the piece to a hardware store and see if they have anything that might work as a replacement.
Hope this helps!
