Question about Tecnik TKL9260 Front Load Washer
My clothes wsher water wont drain...what can I do?
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Wsher gt water in bottom wont drain or wasing saying sensing
Hi Kimberly, I am happy to assist you. Often when a unit does not drain properly, it is because it cannot dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Aug 06, 2013 | Frigidaire Washing Machines
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
Nov 14, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Why won't my washer go to a high speed spin when in the spin cycle? it drains the water out of the drum, but it doesn't go into the high speed spin.
well there is two possibilities and one is a safety precaution to keep from ruining the washer .
if the washer cannont distribute the load evenly it will only go into a slow spin try adding more clothes.... to evenly coat the drum >>. the other is if it is out of balance or the wsher isnt't level it will shake violently and spin in slow cause it detects an imbalance problem if this machine has operated a long time overladed , or unlevel it can wear out the tub schocks which takes all vibrations of the tub to give more of a gently ride the a are like schock absorbers....
Jan 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
Wont drain water Gorenje WA61111
locate the filter and clean, this should cure
Dec 16, 2009 | Asko W600
LHW0050PQ 2 fabric softener does not enter wsher.
top of the drawer may be blocked where the water enters, also check water pressure
Oct 09, 2009 | Washing Machines
LG WF-17014PP will not rinse or spin
check the pump, there is probably a small piece of cloth in there like a sock. This happens all the time. When the motor cant turn the other direction, the locking mechanism to the gears wont engage to do the spin cycle. Turn the wsher on its side, the pump should be easy to remove, they are fasten by two long clips. get back with me if this solves the problem
Jul 01, 2009 | LG WFT1071TP Top Load Washer
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Washer wont drain water
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Jul 12, 2008 | GE WBSR3140DW Top Load Washer
Tecnik TKL9260 Front Load Washer Logo
57 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
