My fan makes a loud noise from my machine is that a problem should I be worried
    Master:
  • 442 Answers
That usually indicates either something has become lodged in the fan or more often, they fan bearings are going out and you need to replace the fan soon. Make sure nothing is trapped in the fan first, if not, then you'll need to get a replacement as soon as possible. If the fan goes out while the PC is on and you're not aware or not around it can overheat and ruin your CPU.
Posted on May 02, 2015
3 Suggested Answers
  • 103 Answers
SOURCE: Loud Fan Noise
Removing from my que
Posted on May 07, 2008
technical114
  • 1851 Answers
SOURCE: cooling fan makes loud noise
Open the side panel of the computer. The inside of your eMachine must be like this:
The only fans in the case are the one inside the power supply and the one over the cpu heatsink. Take a look for something like cable or tire-up to come too close at the cpu fan. In this case take away this cable or tire-up and keep it in a safe distance. Try the results. If the problem is still active try this tip very carefully. Use a drinking straw as brake for the cpu fan. Hear the difference in noise. If the noise is dissapeared your cpu blower needs replacement. KEEP IN MIND THAT YOU MUST NOT RUN THE PC WITHOUT CPU FAN FOR MORE THAN 5 SECONDS. OTHERWISE YOUR CPU WILL BURNED.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 02, 2010
NOISY FRIDGE
hi glenn ,most fridges make this noise but if your worried ring the place you brought the fridge from and get them to send an engineer to check it. good luck
regards
shaun
Dec 09, 2011 | Washing Machines
Ps3 loud fan noise
Don't do anything your fan is just fine it's just running faster to keep it cool when you hear a clicking sound at high speed then you should be worried about it cause your fan is failing and should be replaced
May 31, 2010 | Sony Playstation 3 (PS3) Console
Whirlpool micro wave making loud humming noise fan and light works
Some micros when they get older make more noise. as long as it works I wouldnt worry about it
Jan 12, 2010 | Whirlpool MH7140XF Microwave Oven
OUR XEROX COPY MACHINE MAKES A SQUEALING NOISE WHEN MAKING COPIES
On this model most squeeling noises come from the fuser assembly.
If it is that loud replace the fuser assembly.
Other known prolbems is with the fuser fan in the back.
To see if it is the fuser fan, take off the back cover.
When the machine makes a copy unplug the fan very momentary. See if the noise goes away.
If the noise is still there, then it is possible the fuser is causing the problem.
Make sure the correct fuser is installled on this machine model.
Oct 21, 2009 | Xerox CopyCentre C20 Black and White...
Scratching noises
hithere well if its stopped why worry.......probably due to debri in filter or drain pump.....remove filter ca and check......then check drain pump
regards Sir Galahad
Aug 20, 2009 | Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Apr 18, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
My computer makes a loud noise in the fan
The drive door issue may indicate a virus infection. As to the fan, you would have it replaced. If not under warranty open the case and track which fan the noise is coming from
Mar 25, 2009 | E-Machines eMachines Desktop PC
Playstation 3 cooling fan
Dont worry about it, it is just the fan working.
May 04, 2008 | Sony Playstation 3 (PS3) Console
Computer making strange noise
This is not a problem most people experience this. Its just your fan making noise monstly because it is touching some wire inside. You don't need to worry about this.
Nov 07, 2007 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
