Question about Garden
New regular gas with ethanol, new spark plug, new filter, it won't start manually, like it's not getting a spark or gas. Why?
My neighbor is an electrician, he says everything is working great, just won't start when pull cord, says it's like it has maybe an on/off switch or not getting a spark or gas to it.
  • Garden Master
  • 1,977 Answers
When you take the fuel bowl off to clean also clean the fuel jet as well as it could be plugged as well.
Posted on May 02, 2015
  • 7 Answers
Not sure but fairly certain you don't put ethanol in a mower. Most are not designed for ethanol. Some mowers do have a fuse that can go out. Could even be a safety feature malfunctioning if no spark at all. You could try taking bowl off carberator to see if it is full of gas. Needle might be stuck.
I have a 2007 miller bobcat it has spark cleaned carb new plugs new filter and it won't start
did you try a touch of starter fluid in the carb just to verify that the engine is getting spark? ethanol gas... if it hasn't run in a few months and you left the gas in it... you better revisit the carb cleaning
Dec 13, 2015 | Bobcat Miller 250 Welder Generator 907212...
Model VM200VS will not start or even sounds like it wants to start.
If you cant start it,then go to ebay and buy a new carb,it is cheaper than cleaning and rebuilding it,also get new gas line and in tank filter,ethanol kills plastic
Jul 10, 2015 | Poulan Garden
Won`t start and backfires with throttle or choke
try cleaning carb and running ethanol free fuel with injector/carb cleaner in it
Dec 22, 2013 | Yamaha Kodiak 400 Auto 4x4 ATVs
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Lawn mower won't start
Sounds like gummed up. Remove carb and filter and clean with gas. Clean all lines. Try not to use ethanol
Aug 06, 2012 | Garden
John Deere 17 horsepower Kawasaki engine won't run WOT when blades are engaded
swap the coil with the other side and see if that plug gets sooty instead of the one that has been
May 27, 2012 | Garden
My pro user g5000 generator wonts start after being stood for 6 months any ideas
Hello John, Your gas more than likely has gone bad. If you have spark and good compression and it won't start then chances are the gas has gone bad. Today's gas contains about 10% ethanol, which is absolutely terrible for small engines. Gas with ethanol has a max shelf life of about 90 days under perfect conditions. A month or less is more realistic. Here is the problem, ethanol absorbs water and sits at the bottom of the tank in the generator. If You have a 5 gallon tank With 10% ethanol then 10% times 5 gallons equals half a gallon of water saturated ethanol sitting at the bottom of the tank, I don't care what kind or how good an engine it is, it won't run on water saturated alcohol. Here is a great video explaining it. http://www.youtube.com/watch?v=YeCyFxoWPpo So what I would suggest is to drain the tank and the carburetor bowl of all the old gas. Replace the bowl and check for leaks. While everything is empty I would suggest that you replace the fuel line with a Tygon line. Tygon is resistant to ethanol. I would also ad a see through inline fuel filter and a new spark plug. After this is all done, put in a small amount of gas, less then a half gallon and see if she fires up. If it fires up right away you should be all good to go. Let the generator run until it's completely empty. And store it empty. Here are some problems and solutions that I have for gas with ethanol. I live in Savannah Georgia and the high humidity during the summer can ruin the gas in my lawn tractor in less than 2 weeks due to water saturation. The tractor is almost impossible to start and runs terribly until the remaining gas is used up. I have stopped filling the tank completely and I use just enough gas to cut the lawn then I store the tractor almost empty. I also use gas cans made by a company called Blitz. These containers are pretty much airtight and do not allow the ethanol to absorb water. This has made a tremendous difference in engine performance. Another thing that you can do is to check out this website http://pure-gas.org/ If you are lucky , you might have a gas station that sells gasoline without any ethanol added. This type of gas has a much longer shelf life and if a product like Stabil is added, you might get over a year of safe storage of gas for your generator. Municipal airports have banned ethanol in aviation gas and so have most marina's. It might cost a little more but it sure is worth it when the lights go out. If you can't find pure gas then I suggest you store gas in the Blitz containers for about 3 to 4 months. If you don't need to use the generator then use the gas in your car and refill the Blitz tanks again. Better safe than sorry. I hope this helps and if it does would you please be so kind and give me a positive rating for my solution. Good luck and thank you, Michael Burke.
Jan 04, 2012 | Coleman Electrical Supplies
I have a GMC 2300w AVR generator which is pull start. it starts, runs for a min or two then cuts out..have clean fuel filter, air filter, spark plug, what else could it be...it still cuts out without...
Do you maybe have regular gas in it? Both Canadian and US regular gas now have ethanol in them and if the generator has sat for 2 weeks or longer then the gas is bad.Remove the gas tank and look inside. You will probably see an off-color blob floating around in the bottom. That is our wonderful environment friendly ethanol doing what it does best. Drain the tank and refill with premium. Restart the engine and do what you need to keep it running for about 5 minutes. If it has the plunger primer for cold start, use it every time the engine starts to die, 2-3 pumps each time. If not dribble a little gas into the breather to keep it going. After about 5 minutes it should start running on it's own. If not you will likely have to remove the carb and get the rubber seals replaced. Ethanol and rubber don't mix well.
After this keep premium gas in all your small engines. It doesn't separate. If you want to keep using regular gas then there are additives in the after market that will help keep it from separating. Hope this helps.
Sep 10, 2011 | GMC C2500 Cars & Trucks
My 1998 Buick park avenue burns gas faster than it usually does. What should I do.
If you use ethanol blended gasoline this is normal. ethanol blended fuel doesn't burn as well as regular unleaded
if you use unleaded non-blended fuel
A good thorough tune up should remedy this.
change spark plugs and wires
air filter
fuel filter
engine and transmission oil and filters should do the trick
Aug 29, 2011 | 1998 Buick Park Avenue
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
