Question about Viking Refrigerators
The ice maker drips creating a blob of ice among the cubes
    Sergeant:
    Champion:
  • 253 Answers
Sounds like the ice makers is shot. You may be able to take it out and replace a gasket or o ring in it
Posted on May 02, 2015
What causes my ice maker to drip water?
HI,
This could be either the ice maker is old and the finish inside has depleted, the water valve is going bad or you had a jammed ice cube and now it overfilled. Many different reason this could happen. Does the ice cubes stick together with a bridge? Is the drip coming from the ice maker head unit? How is the ice in the pan its stored in, stuck together? In the pan, has the ice glaciered together? Need more information please. Thanks
Aug 09, 2014 | Kenmore Top Freezer Refrigerator
Jennair refrigerator jfc2089htb2
It is possible that the half side of your=> 67006531 Water Inlet Valve that controls water to ice maker is leaking like a dripping faucet and causing the problem. Can you see signs that water is flowing from the ice maker fill tube? The fill
JENN-Air JFC2089HT Water Inlet Valve Thanks John Tripp Appliance 911
Jan 23, 2014 | Refrigerators
The Ice maker does not make cubes.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Feb 06, 2010 | Refrigerators
Top mont refige; ice maker works but allows water
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it can freeze and block the tube or keep dripping into the ice mold. . You can take the water line off the valve and watch to see if it drips.
Sep 11, 2009 | Refrigerators
Ice maker makes ice cubes, but the doesn't dispense ice cubes.
If you could observe exactly where the water is dripping from it would help but...If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Aug 19, 2009 | Refrigerators
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Mar 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
The water continues to drip after the ice cube maker is full.
Sounds like the water fill solenoid valve is leaking by. You will have to change that solenoid valve if the water continues to drip into the ice maker tray after a normal fill cycle. http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=JCD2295HES&mfgModelNum=JCD2295HES&fkMfgID=1
Dec 05, 2006 | Jenn-Air JCD2295HES Side by Side...
Refrigerators Logo
64 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Joseph Hoffmann
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
