Question about Husqvarna Sewing Machines
Thread bobbin on model 230 - Husqvarna Sewing Machines
  • Lisa McAndrews
    Lisa McAndrews May 04, 2015
    I must be threading the bobbin improperly because it keeps on getting stuck and several pieces of thread are coming through the bobbin opening below the needle. Tension is off too and I don't know how to resolve that.
  • Husqvarna Master
  • 1,860 Answers
Try this link for a manual, it should have the information in it, about how to thread a bobbin
Viking 210 230 250 Instruction Manual
Posted on May 27, 2015
SOURCE: My Singer model 7466 will not pick up the bobbin thread.
I have a singer 7466 that won't sew. I have removed & replaced the bobbin case several times and re-threaded several times and it just won't work. I'm afraid I'll burn the motor! What do I do?
Posted on Aug 15, 2009
  • 26 Answers
SOURCE: top thread will not pick up the bobbin thread
Timing is off, is is possible that you broke a needle or sewed over a pin. timing needs to be re set by a professional.
Posted on Aug 22, 2009
miket756
  • 2702 Answers
SOURCE: NECCHI, model 4795. Thread bunches up at bobbin.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
Posted on Nov 20, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 36 Answers
SOURCE: Singer Model 6233 While sewing the bobbin cas...
If you broke a needle and cannot get it to pick up the thread from the bobbin you need to check your timing. Remove the needle plate and turn the machine over watching the needle, when it is at the bottom of its travel the hook on the shuttle should be right next to or a fraction from the needle. So that as the needle begins to move upward the hook should pass it if it passes to soon it will miss the loop of thread. Check to make sure your needle is installed all the way up in the bar. If your machine is out of time and you are fairly handy, you can retime it. There should be 2 set screws some where behind the shuttle. Loosen them, one loose and one only as loose as need be to turn the shuttle. The needle must have moved upward about 1/16 before the hook is in place to catch the loop. This can be time comsuming, and you will have trial and error. Good luck. P.S. always check for simple stuff before you go for the hard stuff.
Posted on May 25, 2010
Bought a Pfaff 230 sewing machine I have threaded the. Achieve e made sure the bobbin was in right and the bobbin thread will not pick up
Make sure you have installed a brand new needle. If the problem persists, most likely the machine is out of time. Search for sewing machine timing or take it for service.
Mar 30, 2017 | PfaFF Sewing Machines
How to thread a bobbin,sears Kenmore model 158.17031
Place both the bobbin case and the bobbin on the table in front of you. Have the open side of the bobbin case facing up and the bobbin with the thread of the bobbin unwinding clockwise. Drop the bobbin in the bobbin case. Pull the thread tail up through the notch in the bobbin case and then to the left under the thin metal plate until the thread appears to be coming out through the hole in the side of the bobbin case. (When you pull the bobbin thread, the bobbin should turn clockwise in the bobbin case.)
Kenmore 158 17550 Sewing Machine Tutorial
Feb 07, 2016 | Kenmore Sewing Machines
Model 230. Why is it losing the thread at the needle everytime I sew?
The thread sounds like it is not running freely so the upper tension is either too tight or blocked by lint.
If neither of these solutions work then try changing your needle as a blunt or wrong needle can also be a cause
Nov 29, 2015 | Consew Sewing Machines
How to thread bobbin on model 230
Hello Lisa; 'would love to help you. What is the machine brand?
May 02, 2015 | Husqvarna Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. (http://www.singerco.com/accessories/instruction-manuals has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
Jan 19, 2012 | Singer Sewing Machines
I need a manual for a model 230 consew, I recently bought it from a friend, I want to learn how to thread it, and wind my bobbins, can you help me, unable to find one
You can go to the consew official website and download the PDF file for the 210 model. It's the same as the 230 r-1 (which i have). I found this information by calling the consew headquarters. You can also download a PDF with the full parts list for the 230 model specifically. This link may help http://www.consew.com/default.aspx?pageId=4
Apr 06, 2011 | Sewing Machines
I want to adjust my bobbin tension on my 230 viking sewing machine but I don't know how.
1. remove the clear bobbin cover
2. slide the needle plate towards you and remove it, do not pry it upward or you'll break the gray plastic housing that supports it.
3. remove the gray plastic piece that is on top of the black bobbin case.
4. remove the black bobbin case from the machine.
5.Look on the side of the bobbin case for a small hole with a screw deep inside of it. That is your tension screw. Turning it to the right increases the threads resistance and left loosens it.
You know you bobbin tension is in the right range with the following test: Have your machine in the ready to sew positon. Meaning the bobbin has thread on it and it's in the machine and the bobbin thread is coming up through the needle plate. Gently pull on the bobbin thread to feel the amount of resistance. It should be slight not tight. If you pull on the thread and feel a light resistance your problem is not your bobbin. If you have looping on the bottom of your fabric, the problem is the top thread.
Dec 27, 2009 | Husqvarna Sewing Machines
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
