Question about LG WM Washing Machines
What does oe mean on led display
WONT FINSH CYCLE,AND LED DISPLAYS OE.
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Posted on May 05, 2015
    Genius:
  • LG Master
  • 1,585 Answers
Check pump for blockage
Posted on May 03, 2015
Wash cycle works ok but will not spin and oe appears in digital display then it switches off. We have just had drum and shaft and bearings replaced, repair man ran it then when we trid to use it it has...
This is what "OE" Means :
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Feb 09, 2011 | LG Washing Machines
My machine just stopped during the cycle, and displayed 'OE'. What does this mean? Why did it do it?
The OE is an overload error. Try removing some clothes. If that does not work you could try unplugging the machine. I have a manual you might want to look through. LG washer manuals
Sep 19, 2010 | LG WM-2032H Front Load Washer
Gives me an OE on the display
It's the pump motor -Plug your machine and run a test cycle and check for some grinding noise. Pulled the pump out from under the washer instead of taking the whole thing apart much, much easier.
Apr 10, 2010 | Asko WL6511W Front Load Washer
What does "OE" mean?
i believe its a drain problem
Feb 13, 2010 | LG Dishwashers
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 29, 2009 | Washing Machines
Washing Machines Logo
108 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
