Question about Rescue Pack 950 Jump Starter
Rescue 950 unit does not charge. red led does not come on. Got it for Christmas 2014
Checked home power outlet and has voltage. Led does not come on.
    Scholar:
    New Friend:
  • 95 Answers
Is there something on the inside to show that the battery inside the unit is actually connected. you may have to take of ft he back and make sure the connectors to the battery are actually hooked up.
Posted on Nov 17, 2015
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Vectron wave toy doesn't charge
2Hz is probably the ripple current from the charger.
Apr 14, 2017 | Spinmaster Spin Master Air Hogs Vectron...
NOT GETTING ANY POWER WHEN TURN ON/no red light when hook to power outlet? checked power source okay. just bought this led tv about 3-4 months ago.
Possible that the mP section is not working , As confirmed the power supply SMPS unit is working but the secondary voltages must be checked to see if the regulator for the processor gets the supply. If not check and replace, if supply is through then the mP must be checked.
Need to check is warranty cover is availabel to you , if so call without tampering.
Sep 30, 2010 | Samsung LN32A330 32 in. LCD TV
No power. All power cords checked and tight. With
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 06, 2010 | Gateway MP6954 Notebook
All off led flashes 5 times only and just repeats at mains reset
Accordingly, the 5 blinks is a fault code that means the voltage in the main power is abnormal.
  1. Unplug the unit for 15 minutes while checking the voltage on the AC outlet using a multimeter.
  2. If the voltage is not as what it should be, use a different outlet or have it checked by a qualified electrician.
  3. If the voltage is normal, check the power supply unit for any bad capacitors. Here are the samples of bad capacitors.
Nov 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No power from ac adaptor
No, there are no reset button or fuse in these laptop adapters, they are a sealed unit. The lead/plug maybe broken at the plug. Test the voltage at the plug with a multi-meter, the output voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 21, 2009 | Toshiba Satellite Pro L300 Notebook
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Coleman 1500 power inverter has no output
I believe that the actual unit may have other problems and that you will need a schematic to aid in your troubleshooting of this issue. Once you have the schematic and a multiment you can check the voltages to see if things ar as they should be and then we can look at what is happening.
Sep 01, 2007 | Statpower PW-1750 Triple Outlet 1750 Watt...
UPS TRIPS AFTER 30 SECONDS
dear, This problam is related to battery and i am sure your battery is faulty pls replace it.
Aug 31, 2007 | Computers & Internet
Rescue Pack 950 Jump Starter Logo
102 people viewed this question
Top Quick Cable Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Quick Cable Vehicle Part and Accessory Expert? Answer questions, earn points and help others
