Question about Garden
What cause my mower to shut down after 15 minutes of operation? seems fuel deprived but filter and pump are clean
This is a constant event
    Sergeant:
    Champion:
  • 253 Answers
You probably don't have the gas tank vent opened up, check the cap and see if the little hole in it is plugged up. The tank has to be vented or it will cause the motor to stall, because it can't get gas.
Posted on May 02, 2015
  • 753 Answers
Make sure the fuel cap vent isn't clogged try running with the cap off. what mower is it.
    Sergeant:
  • 266 Answers
Is it still under warranty? Is it overheating? Check oil.
What causes a Poulon Pro riding mower with a 19.5 HP Briggs to shut down after only running for about 15 minutes?
Will it start rite back up?
Check to see if you have a low oil sensor,
Sometimes the oil sensor wills me it shut off when it's a little low on oil.
May 17, 2015 | Poulan Pro 19.5HP Lawn Tractor 960420123
Engine runs 15 or so will shut off and starts when cool. Replaced fuelfilter and fuel pump relay. still does the same thing.
If you don't have any check engine warning light on your dashboard relating to EGR system means it has to be the FUEL PUMP according to you fuel pump relay and fuel filter was replaced but the most common cause by that is fuel pump...to verify have you try to install Fuel Pressure Tester to a fuel line it might not be the specified psi while observing the tester a several minutes tester shows it dropping down the pressure till it shut off by itself.
Dec 09, 2014 | Cars & Trucks
21 hp briggs and stratton run for about 15 minutes then shuts down then i see the fuel filter is empty
Check out the small fuel pump vacuume located between the fuel tank, engine, and hose to the carb. You may need that part because the same thing happened to my brothers mower.
Oct 01, 2012 | Measuring Tools & Sensors
1999 astro/4.3L/starts cold /runs 10-15 min. then dies will not start hot new battery.new coil/clean filter/pump 2 yrs old installed new/battery shows 14 amps when running/ won t crank when hot either/...
car shuts off when it gets to normal operating range. it takes 10-15 minutes to reach normal range. causes: low coolant, failing coolant tempurature sensor, air in water pump, check the coolant temp. sensor. if it is bad it will send wrong info to engine when hot, and shut it down. ITS WORTH A TRY!! good-day!
Sep 15, 2011 | 1999 Chevrolet Astro
Tractor will shut down and will not start up again
Three things, replace air filter, replace fuel filter, and take carb off and clean it out, could have sediment in jets or float is sticking causing not enough gas to run through stalling out motor.
Aug 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have to choke MTD to keep it running
check fuel pump diaphram is not streched or hard, check fuel filter for blockage, or fuel tank cap might be not venting, if none work drain and clean out carby bowl.
Jul 19, 2009 | Mtd LAWN MOWER PART # 787-01341...
Engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Apr 25, 2009 | Garden
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
