Question about Home
How do I disconnect the SofFlow Bidet toilet seat? How do I turn off the water flow?
2 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: I'm looking for the solution to a problem with a
My advice is to cut the water supply first and empty the tank ...cause if after flashing the leak stops and after a while gets back ..even if you do not flash .. it means that the leak is under the top level of the tank ..and this is the reason that it is present all the time but a few minutes after the flash ..
Than , get a plumbing silicon tube ..(lever action) from the local hard store...and just seal the crack inside if it is possible ..and outside on a larger area just to be sure...All you have to do is degrease the surface by cleaning it well with what ever you use to clean the bathroom ..and apply the silicon ...it will seal it well and it is almost colorless ..and this is the advantage ..after the drying will have a rubber like texture..but will not be visible ..and will seal it perfectly ..and it is water-resistant ..
here is an idea about what I'm talking ...
by the way this can be used to seal bathtubs ..and even glue the sink to the wall if the surface is perfectly smooth ..so the rest is usable for various purposes..
http://www.videojug.com/film/how-to-seal-around-a-basin-or-bathtub
Posted on Oct 02, 2010
Im looking for intelliseat toilet temperature sensor
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat, Bidet Seats ...
https://www.amazon.ca/IntelliSeat-Ultimate-Bidet-Electronic-Toilet/dp/B0050EJBQ0
  1. Cached
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat in Bidet Seats. ... Bio Bidet BB-i3000 Premium Dual Temperature Bidet Toilet Seat, White ยท 4.3 out of 5 stars 18. CDN$ 179.00 .... Maybe the sensor on the Seat is not working? I am contacting ...
Intelliseat Bidet Toilet Seat - Proper Wash
www.properwash.com > Electronic Toilet Bidet Seats
  1. Cached
  2. Similar
IntelliSeat, is one of AMDM's featured innovations bidet toilet seat, and after one use ... Toilet sensor permits operation only when skin contact is made ... Water Heater; Endless Warm Water; Heated Seat (adjustable temperature); Increased ...
AMDM IntelliSeat the Ultimate Bidet Electronic Toilet Seat - Amazon.com
https://www.amazon.com/product-reviews/B0050EJBQ0
  1. Cached
However, if you have a newer elongated toilet, the Intelliseat will probably fit just fine. ... Maybe the sensor on the Seat is not working? ..... Both seats have LED indicators for seat temperature and water temperature, but only the Intelliseat has ...
Intelliseat is a must for modern toilets - Pilot Bidet
pilotbidet.com/intelliseat-is-a-must-for-modern-toilets.html
  1. Cached
  2. Similar
IntelliSeat is one of the most advanced toilet apparatuses and after one use you ... These sensors can sense the presence or absence of a human body on the ...
=$= AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w ...
https://betojhkitchenbath.wordpress.com/.../amdm-intelliseat-the-ultimate-bidet-electro...
  1. Cached
Mar 20, 2013 - AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w/ ... Water Glow LED Faucet Light with Temperature Sensor Three Optional Colors ... intelliseat toilet temperature sensor Google Search
Dec 04, 2016 | Ovens
Plumber replaced the tualet and moved the bidet to the new seat and it stopped working
Did he forgot to turn the water back on? Pretty common to forget to turn the water back on.. Fallow the water line from the bidet and turn the valve to the right (Right valve turn is standard in US) to see if it turns the water on.
Hope this helps FixYa issue.
Mar 26, 2016 | Home
Hot water stopped working. How can I get it to heat up the water again?
Wow. Are you kidding? Toilet paper is very reliable and has no working parts to break...
Dec 17, 2015 | AMDM Intelliseat - The Ultimate Bidet...
How difficult is it to replace toilet tank equipment?
The job is easy if you have any plumbing skills. Turn off the water. Disconnect the water hose at the bottom of the tank. Remove the nut holding the flush/fill mechanism and remove the mechanism. Reverse removal procedures and complete. Adjust for proper water level in tank.
Dec 03, 2014 | Home
My Toto toilet runs after a flush. If I turn the water supply off for a day or so it will stop running but will do it again after a couple of days
If your Toto toilet has some sort of flapper, it may not be seating properly or may be defective.
Jul 30, 2014 | Toto Home
Water is not hot
Heating needs to be turned on from the remote control. If the indicator is lit properly, then the heater is defective and must be repaired.
Feb 01, 2014 | AMDM Intelliseat - The Ultimate Bidet...
Why can't we get the nozzle to move?
If you need a replacement part that includes a functional nozzle, you can purchase it here http://www.ebay.com/itm/Intelliseat-AMDM-ISB-200-body-Replacement-/222019823660?hash=item33b169a82c:g:v8QAAOSwzgRWvLSS
Aug 27, 2013 | AMDM Intelliseat - The Ultimate Bidet...
I bought intelliseat electronic toilet seat but i couldnt find the remote control for the seat :( What can i do ??
Nothing will operate without a functioning remote control; you'll need to buy one from the manufacturer. I recommend attaching the bracket to the wall, and Velcro-ing the remote into the bracket, so that it won't get lost or fall into water.
Mar 03, 2013 | AMDM Intelliseat - The Ultimate Bidet...
A small jet of water is released up through the seat onto the person seated
You have a bidet:
http://www.amazon.com/Luxe-MB110-Non-Electric-Mechanical-Attachment/sim/B001KKRCFA/2
Google search for 'toilet seat bidet'
As general rule, men do not use this feature.
Change toilet seats to remove bidet.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on toilets or any do-it-yourself project.
Jan 12, 2011 | Eljer Aqua-Saver 12" Two-Piece...
Home Logo
319 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
