Question about Garden
Kohler courage xt-6 engine won't start. Replaced Spark Plug
    Genius:
  • 1,585 Answers
Check for spark
Posted on May 03, 2015
What is causing my pressure washer engine to stop hard/suddenly?
Your engine is experiencing a heat seizure... the piston sticking in the cylinder as it expands under heat with poor lubrication.
May 02, 2017 | Garden
My lawnmower make use of a Kohler Courage XT-7 engine, run for 13 hours and thereafter do not want to starts.
the shear pin is partly brke under the flywheel . replace it and should be OK
Mar 04, 2016 | Cars & Trucks
How to test engine coil on 19 hp kohler engine
Get yourself a test spark plug for small engines
There is a small engine one & one for car with HEI
Ignition
Looks like a spark plug with an alligator clip on it
Look on the internet for one similar to KD 2757
Has to be for small engine & std ignition-- not electronic
ignition systems
Oct 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How to change the spark plug on a Husqvarna 6021P 21 inch
I use a spark plug wrench or a deep socket and turn counter clockwise.
Jun 16, 2014 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Gas leaking from carb when not in use.how to fix.
clean the float needle and check its not ridged where it seats ! if so replace !
May 27, 2014 | Kohler NET HP COURAGE XT-7 SERIES VERTICAL...
Wont spray
I hope the engine wont spray... if it's a pressure washer thats not spraying the name of the unit would help... but does it build pressure but doesn't spray - check the wand
does it even build pressure ??? no - replace pump
Oct 18, 2013 | Kohler NET HP COURAGE XT-7 SERIES VERTICAL...
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
MY NEIGHBOR KOHLER COURAGE 20 LTX1045 WILL TURN
check and see if it's getting spark by removing the plug from the engine and keeping it plugged into the wire,lay the plug on the head and turn the engine over and look to see if the spark is jumping accross the gap. if it's blue your ok if it yellow you'll have to replace ignition modual..good luck
Apr 10, 2010 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
