Question about Rand Mcnally GPS
I bought my rand McNally 710 at a swap & shop. How do I get free up dates?
3 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: Droped my new rand mcnally gps and cracked the
You can replace a cracked GPS screen, but you can't repair it. If your GPS is under warranty, you can contact the manufacturer directly about sending the unit back to have the screen replaced. If the device is not under warranty, you can still contact the manufacturer about replacing the screen. The company will charge a fee to replace your GPS screen if you don't have a warranty that covers that type of repair. You can also replace the GPS screen yourself, but be aware that replacing your GPS screen can void your warranty.
Instructions Things You'll Need
  • Mini Philips screwdriver
  • Flat-head screwdriver or other pry tool
    • 1 Purchase a new GPS LCD screen. There are many sources online that sell GPS screens (see Resources). Look for compatible unit information next to each replacement screen online before purchasing it to make sure it matches your GPS model.
    • 2 Power off the GPS and remove any peripheral cables from the device.
    • 3 Remove the screws from the cover. The number of screws varies depending on the GPS; there may be two to four screws located on the bottom or rear of the GPS. You will need a mini Philips screwdriver (like those found in computer repair kits) to loosen the screws.
    • 4 Remove any further screws holding down the internal antenna.
    • 5 Wedge a flat-head screwdriver or another pry tool in between the front and back case of the GPS. Use the pry tool to pull the front and back cover apart. Once open, you may notice that the back cover contains a battery or other component, and the front cover houses the motherboard which is over the screen.
    • 6 Touch a piece of metal, such as a metal tool or metal door knob, with your hand to demagnetize yourself. This prevents the motherboard from being destroyed by any static electricity in your body.
    • 7 Remove any screws holding the motherboard to the front of the case. Then move the motherboard out of the way when it is loose enough. The motherboard will still have wires connected to different components that are embedded in the front of the GPS case.
    • 8 Disengage any wires that are connecting the motherboard to the front case components such as the SD card or phono/audio jack. There is typically a lever that must be pushed to disengage these wires.
    • 9 Pull the screen's ribbon cable connection from the motherboard. Be careful, the ribbon cable is delicate. Discard the old, cracked screen. You can now insert your new screen into the front cover of the GPS. Reconnect all of the ribbon cables and wires that you disconnected to remove the motherboard, and close the GPS case back with the required screws.
    HERE IS THE LINK BELOW TO COPY AND PASTE AND PUT IN YOUR BROWSER AND THIS IS YOUR OPTIONS, CAN CONTACT THEM AND SEND IT IN AND THEY CAN REPLACE IT FOR YOU, OR CONTACT THEM AND HAVE THEM SEND YOU OUT THE PART AND REPLACE YOURSELF, BASED ON INSTRUCTIONS I LISTED ABOVE.
http://store.randmcnally.com/?SCCampaign=cjaff&gclid=CPe2iu2B36oCFVAaQgodIwM58g
MY ADVICE IS : Sense your unit is expensive and new, it is worth having them fix it or fix yourself. I hope hope this helped you, and on the good size you for sure have a good unit. Thanks Mike , your fixya Expert.
Posted on Aug 20, 2011
emissionwiz
  • 80608 Answers
SOURCE: rand mcnally tnd 710 not turn on
If it is more than a few years old then the battery is a real possibility as the problem.
Posted on Apr 20, 2012
Rand McNally 710 has no sound
The sound may have been turned off accidentally.
Mar 07, 2017 | Rand Mcnally GPS
How do you get to and replace fuse in power cord for rand McNally 710 gps
Deborah, most of the time the fuse is in the cigarette lighter. The end unscrews. However, if that fuse blew, you may have wiring that has shorted. Much more common to blow you lighter fuse, in the car. Happens with plugging in and turning the "lighter" body, and shorting the lighter socket.
May 18, 2016 | Rand Mcnally GPS
How do you change the time on the new rand mcnally tnd tablet to daylight savings time
To ensure the correct time is on your tablet to to the settings menu. Then select Date & Time. Check the boxes for Automatic date & time and Automatic Time Zone.
Please contact Rand McNally support if you require additional assistance.
Technical Support is available:
Monday - Friday
7am - 6pm (CST)
1-877-446-4863
Mar 09, 2015 | Rand Mcnally GPS
I have recurring issues with charging/power plug. TND 710.
Have you tried cleaning the CONNECTIONS, both male and female, using a good CONTACT CLEANER?
May 11, 2017 | Rand Mcnally TND 710 GPS Receiver
Not talking
Well not sure that you posted this in the right section. If you are talking about a Rand Mcnally TND 710, then yes it won't give you text to speeech, that feature is not in the 710 the 720 or even the 510 or 520.
Sep 06, 2013 | Rand Mcnally TND 710 GPS Receiver
Rand mcnally 710 navi.exe has encountered error
go on lione and do the back up anbd reset to factgory setting it should be ok
Mar 05, 2013 | Rand Mcnally TND 710 GPS Receiver
Gps dont get on
If the GPS is more than 2 years old the battery may have failed from age. If you believe that is not thwe cas ehere then contact customer service at Rand Mcnally.
Nov 05, 2012 | Rand Mcnally TND 710 GPS Receiver
Rand mcnally tnd 710 not turn on
Apr 19, 2012 | Rand Mcnally TND 710 GPS Receiver
GPS Logo
41 people viewed this question
Top Rand Mcnally GPS Experts
Steve F
Vuk B
Are you a Rand Mcnally GPS Expert? Answer questions, earn points and help others
