Question about Garden
How to assemble the handles - Garden
    Sergeant:
  • 253 Answers
Check the manual
Posted on May 02, 2015
How do I remove the LCD Housing from the Handle Assembly
The lcd and housing should have been removed from the previous handle...if you have thrown them away then you will have to order the new parts.
May 16, 2017 | Fisher & Paykel DD24DCTB6 Double Tall...
How to replace hatchback handle assembly
You need to get into the boot space remove trim card on boot lid then you will see lock assembly find the link rod to the catch flick it with a screwdriver and the boot will open to change the locl assembly is quite easy you will need TORX bits to remove fixing screws good luck.
Jun 22, 2014 | 2000 Ford Focus
Headlight exchange
Above each headlight assembly behind the radiator bulkhead there are two black "handles" that are for the latches that hold the headlights in place. Pull these handles up, and the headlight assembly should slide out the front. You can then replace the bulbs or, if you wish, the entire assembly. When done, just slide the assembly back in place and push the latch handles down. It should take about 5 minutes for each side.
Dec 28, 2013 | 1994 Oldsmobile Bravada
Need to get handle off of pantera sand filter
You need to remove the "key assembly" before removing the handle. The key assembly is the lid, handle and diverter which all come out in one piece after taking the bolts out around the lid.
Once the assembly has been removed, you need to compress the lid down toward the diverter to allow the handle to move freely. At that point the handle pin, which connects the handle to the diverter may be removed. Note the position of the handle's pointer and the open slot on the diverter. When reassembling it is important that they are in the same position. If not careful the handle will be 180 degrees off.
Its a good idea to go ahead and change out the diverter o-rings and bearing on top of the lid (that the handle slides upon while turning) while you have it open.
Mar 13, 2013 | Pool & Spa
Pullstart cable broke
Remove nuts mounting recoil assembly. Observe how rope is wound around pulley. Find end knot in pulley wheel. Cutoff end knot and remove old rope. Find end knot in handle, use needle nose pliers pull thru old rope. Rope is sold by the foot at mower repair shops. Replace rope as observed before removal. Cut to size after wrapping recoil assembly and attaching thru handle at proper length if at recoil assembly or on mower handle. Ensure good knot in hole of recoil assembly and handle.
Sep 22, 2012 | Toro Power Lawn Mower
It will not flush properly .rudy
How to Troubleshoot a Flushometer
A flushometer consists of a metal pipe extending from the back of a toilet with a slender handle on the side that is used to flush a toilet. This type of flush valve is commonly used for toilets in commercial facilities to provide a durable and accurate flush delivery system. If the flushometer does not work properly, troubleshoot it and perform minor repairs. Common issues are often resolved quickly. If troubleshooting does not correct the problem, call a plumber for repairs.
Does Not Flush
1 Inspect the handle assembly. A broken handle or assembly will prevent flushing. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it with a handle repair kit
2 Open the main water supply valve to turn the water on fully. The water supply is normally turned on, but check to make sure it is turned on fully and has not been turned off inadvertently
3 Remove the flushometer's CP cover, the round cap on the very top of the pipe extending from the toilet. Then remove the inside cover directly underneath the cap. Inspect the relief valve. Replace it if it is visibly damaged.
Short Flush
1 Remove the CP cover and inside cover. The CP cover is located on the very top of the pipe extending from the back of the toilet. The inside cover is underneath the CP cover and the diaphragm assembly is located beneath the inside cover. Remove and inspect the diaphragm assembly. A damaged diaphragm assembly can cause a short and incomplete flush. Replace it if it is visibly damaged.
2 Replace or repair the handle assembly. A damaged handle can result in a short flush. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it using a handle repair kit.
3 Remove the CP cover and inside cover to remove the diaphragm assembly. If a low consumption diaphragm is installed on a water-saver fixture or a urinal diaphragm is installed on a toilet fixture, replace it with an appropriate diaphragm.
Mar 04, 2011 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
How to replace the outside rear door handle
Remove the door panel, release the retaining clips for the rosds going to the door handle, Remove door handle assembly retaining nuts, remove door handle assembly. Reverse order to reinstall.
Jan 08, 2011 | Chevrolet Silverado 1500 Cars & Trucks
The left rear door window fell off the track. How do I remove the door panel to access it.
This is the complete procedure you stop when you see the problem.
1. REMOVE REAR DOOR INSIDE HANDLE BEZEL
(a) Remove the screw.
(b) Using a screwdriver with its tip taped, disengage the 2 claws A.
(c) Pull out the the rear door inside handle bezel in the direction indicated by the arrow, disengage the claw B, and remove the rear door inside handle bezel.
2. REMOVE DOOR PULL HANDLE
(a) Using a screwdriver wrapped with the protective tape, disengage the 2 clips and remove the door pull handle.
3. REMOVE REAR DOOR TRIM BOARD SUB-ASSEMBLY
(b) Disengage the 7 clips.
(c) Disconnect the connector and pull up on the rear door trim board sub-assembly to remove it.
4. REMOVE REAR DOOR INSIDE HANDLE SUB-ASSEMBLY
(a) Remove the bolt.
(b) Disengage the 2 claws and separate the rear door inside handle sub-assembly.
(c) Disconnect the 2 cables and remove the rear door inside handle sub-assembly.
5. REMOVE REAR SPEAKER
6. REMOVE REAR DOOR SERVICE HOLE COVER
(a) Disconnect each connector and remove the rear door service hole cover.
HINT:
Remove the remaining tape on the door side.
7. REMOVE REAR DOOR GLASS RUN
(a) Connect the window regulator switch assembly.
(b) Fully lower the door glass.
(c) Remove the rear door glass run.
8. REMOVE REAR DOOR WINDOW DIVISION BAR SUB-ASSEMBLY
(a) Remove the 2 bolts, the screw and rear door window division bar sub-assembly.
9. REMOVE REAR DOOR QUARTER WINDOW GLASS
(a) Pull out the direction indicated by the arrow, remove the rear door quarter window glass and rear door quarter window weatherstrip as a unit.
10. REMOVE REAR DOOR QUARTER WINDOW WEATHERSTRIP
11. REMOVE REAR DOOR GLASS SUB-ASSEMBLY
(a) Remove the rear door glass sub-assembly as shown in the illustration.
(b) Disconnect the window regulator switch assembly.
12. REMOVE REAR DOOR WINDOW REGULATOR SUB-ASSEMBLY
(a) Disconnect the connector.
(b) Loosen the temporary bolt.
NOTICE:
If the temporary bolt is removed, the rear door window regulator may fall and become deformed.
(c) Remove the 3 bolts and the rear door window regulator sub-assembly and the power window regulator motor assembly rear as a unit.
(d) Remove the temporary bolt from the regulator.
13. REMOVE POWER WINDOW REGULATOR MOTOR ASSEMBLY REAR
(a) Using a "torx" driver (T25), remove the 3 screws and power window regulator motor assembly rear.
14. REMOVE REAR DOOR LOCK ASSEMBLY
(b) Remove the bolt.
(c) Using a "torx" socket wrench (T30), remove the 3 screws.
(d) Slide the rear door lock assembly downward, pull out the link from the outside handle frame, and remove the rear door lock assembly and cables as a unit.
(e) Remove the door wire harness packing.
(a) Using a "torx" socket wrench (T30), loosen the screw.
(b) Disengage the 2 claws and remove the rear door outside handle cover.
(a) Disengage the 2 claws and remove the rear door outside handle pad rear.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
Jan 03, 2011 | 2006 Toyota Highlander
The interior door handle on the driver's side of my 2000 Tundra does not open the door. The exterior door handle works fine. I would assume the cable has broken on the door latch portion. What is the...
remove the screws that fasten the interior door panel to the door.  Visually inspect the handle assembly. there will be two cables that connect the handle and lock button to the door lock assembly.  I would bet that the L-shaped end of the interior door handle cable broke.  The replacement is self explanatory for the handle. Google the door lock assembly which isn't as visable.  Bob
Jan 10, 2010 | 2000 Toyota Tundra
Installing exterior driver side and passaner side door handles
I found this on another page, hope it helps:)
Remove the plastic cover behind the door handle assembly by removing one black 14mm nut from just above the door handle, and 1 screw (usually phillips) from the bottom of the plastic cover.
Remove linkages from lock cylinder and door handle assembly. Use a small flathead screwdriver to slide retaining clips forward, and linkages will come free.
Remove one black 14mm nut from the very top of the door handle assembly.
Remove one phillips screw drom the bottom of the door handle assembly.
Door handle assembly should now come free by pulling out slightly at the top, and pulling upwards.
Transfer lock cylinder and key minder light (if applicable) to new door handle assembly. Lock cylinder is retained by a single TORX bolt.
Reinstall in reverse.
TIP: If you lose or damage any of those black plastic coated nuts, order new ones. They are GM p/n 10067214 and should be around $0.58/each. There are two on each door.
Mar 02, 2009 | 1995 Pontiac Grand Prix
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
