Question about Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012
How do I remove the original hose and connect thwe replacement
    New Friend:
  • 3 Answers
There are two versions of the 51012, mine is the 51012 2 (it isn't marked that way, I had to compare the two in the manuals I found online).
The hose ends in a metal pipe that goes into a flange in the unit, held in place with a cotter pin. Pull the pin, pull out the pipe, insert the new pipe all the way, and put the pin back in. That's it. Once I figured it out it only took 5 minutes. Good luck!
Posted on Jul 02, 2016
  • 696 Answers
Hi Mark
Where the hose attaches to the machine, you'll likely have a "collar" that you will be able to turn
Slide that sucker away from where the hose comes to it and you'll free up the connection.
-Steve
Posted on May 02, 2015
How to remove a radiator 03 Mercury Mountaineer 4.0 engine V6 I checked the hoses they're good, but small drops of fluid is coming from the bottom of the radiator looking like it coming from the hose
What is the problem exactly?
If the radiator itself is not the source of the coolant leak why do you want to remove it from the vehicle?
You will certainly be able to locate the leak if it is from the radiator unit itself and in that event you will need to replace it.
If you have a leaking radiator hose or the hose is too loose on the bottom radiator neck then you replace the hose or tighten the hose clamp if it is the adjustable type.
If the radiator hoses connected to the radiator are the 2003 originals then they will definitely be well passed their use by date and should be replaced in any event.
Dec 12, 2015 | Mercury Cars & Trucks
How to remove waste hose from machine?
1 Turn off the circuit breaker that controls the dishwasher.
2 Open the dishwasher door. Locate the two small screws holding the bottom valance trim piece. Remove the screws and the valance, revealing the lower pump assembly and drain-hose connection.
3 Remove the hose clamp. Disconnect the drain line by pulling the hose.
4 Find the other end of the drain line under the sink; it is connected to the drain tail piece or the garbage disposal. Remove the hose clamp and disconnect the drain line. The dishwasher drain hose is now disconnected at both ends.
5 Pull the dishwasher drain hose into the sink base through the hole between the dishwasher and the sink base.
6 Take the dishwasher drain hose outside or to a wash sink. Run hot water through the line to clean and unclog it. When you see water running freely through the hose, then it is clean. If the hose cannot be cleaned, replace it with a new drain hose of the same size and length.
7 Feed the clean dishwasher drain hose back to its original configuration. Reconnect both hose clamps. Reinstall the valance, turn on the circuit breaker and test-run the dishwasher.
Nov 29, 2010 | Smeg CSU2001 Built-in Dishwasher
I need a diagram to replace a fuel tank on a 1987 vw cabriolet
1987 Volkswagen Cabriolet 1.8L FI SOHC 4cyl
1985-89 Scirocco and Cabriolet
  1. Disconnect the negative battery cable and drain the fuel tank.
  2. Remove the rear right wheel housing cover.
  3. Disconnect the large breather hose from the filler neck.
  4. Pull the gravity valve down leaving the hoses connected.
  5. Unbolt the fuel pump bracket from the body and lower the pump.
  6. Remove the fuel tank screw.
  7. Disconnect the fuel pump hose and pull the blue hose from the return line.
  8. Disconnect the brake hoses from both sides of the rear axle and plug them.
  9. Disconnect the rear axle from both sides of the body and allow it to swing down and rest on the handbrake cable guides.
  10. Unhook the rear muffler support lugs.
  11. Disconnect the filler hose from the tank.
  12. Support the tank, remove the tank fasteners and lower the tank enough to disconnect the fuel gauge sending unit wires and breather hoses.
  13. Remove the fuel tank.
To install:
If installing a new or used tank, make note of where the old foam strips were installed, and install new foam strips on the replacement tank in the same locations.
  1. Raise and support tank. Connect the small breather hoses and fuel gauge sending unit wires. Install the tank fasteners.
When connecting the breather hoses, position the hose clips so that they do not make contact with the body.
  1. Connect the filler hose to the tank and connect the rear muffler support lugs.
  2. Raise the rear axle off the handbrake cable guides and install.
  3. Connect the brake hoses and bleed the brakes.
  4. Connect the return line and fuel pump hose.
  5. Install the fuel tank screw.
  6. Raise the fuel pump and attach the fuel pump bracket to the body.
  7. Put the gravity valve back into its original (raised) position.
  8. Connect the large breather hose to the filler neck.
When connecting the breather hose, position the hose clip so that it does not make contact with the body.
  1. Install the right rear wheel housing cover.
  2. Fill the tank and connect the negative battery cable.
Fig. 1: Fuel tank assembly used on the Rabbit Pick-up. Other models are similar
Hope helps (remember to rate and comment this).
Sep 21, 2010 | Volkswagen Cabriolet Cars & Trucks
Why is my washer machine is not filling up after i changed the water pump?
I need more info but 1 did you turn thwe water back on.2 you may have jerked the pressure switch hose loose it is a small 1/4" hose that comes from the top console to the lower side of the tube pressure must go up this and start the agitation. also the drain hose must be higher than half the washer
Apr 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Bad fuel
Turn off fuel tap ,disconnect fuel pipe from carbs .drauin fule using tank tap into container ,or remove thwe tank from the bike ,take care to remove all pipes connected to frame work .like overflow pipe / breather pipes etc etc .
Mar 24, 2010 | 2004 Suzuki VL 800 Volusia
I have a 98 lincoln town car executive and I need to know how you change the thermostat
1. drain coolant
2. remove engine cover
3. remove the 2 bolts from water hose connection (upper rad hose connecting to)
4. remove o-ring and thermostat
5. repeat in reverse order
Feb 05, 2010 | 1998 Lincoln Continental
The removal of the heater hose under the intake
Do a little research on the hose first. Some are preformed and they resist kinking better than a straight universal hose that may be harder to bend into place.
If you do this repair with the engine cold it will save you some antifreeze. There will still be leakage but less than on a warm engine. After you have the new part, cut off the old hose and it will be easier to remove the hose clamps.
Hopefully the original spring clamp will be on the hose ends. Do not use the screw type clamp as they always have uneven pressure. Slip off the hose clamp by squeezing the tabs and once removed slit the old hose to keep from being rough on the metal parts that you must remove the hose from.
Sometimes a little water to lube the new hose will help the new hose slip over the metal fixtures.
Hope this helps.
Feb 10, 2018 | 1996 Lincoln Town Car
Heater hose was cut and caused to loose all coolant
First what kind of motor do you have 2.5l, 3.1L?
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Mar 31, 2009 | 1992 Pontiac Grand Am
Rear water spray
You need to check the hose that connects to the spray noale in thwe back. It might have dry rotted or disconnected. I hope this helps. Don,t forget to rate my answer, thanks.
Feb 27, 2009 | 2000 Ford Focus
Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012 Logo
1,376 people viewed this question
Top Greenworks Garden Experts
richie46
Josh Van Nostrand
Steve
Steve
Are you a Greenworks Garden Expert? Answer questions, earn points and help others
