Question about Water Water Heaters
Why do I have to have an external feed at bottom?
Manufacturer builds in a dip tube to feed cold water to bottom
    Sergeant:
  • 415 Answers
Having the dip tube routed to the bottom will keep the water circulating in the tank. Drawing out from wither the top or bottom will make no discernible difference.
Posted on May 04, 2015
Does an Intertherm water heater model HSE 30F 240S have a dip tube? Cold water comes n on the side of the tank not on top or bottom.
How to Repair or Replace Defective Water Heater Dip Tubes
www.familyhandyman.com > Skills > Plumbing
The role of the dip tube is to direct incoming cold replacement water to the bottom of the tank for heating. While it warms, the dense, cold water stays naturally segregated from the warmer, lighter water floating on top. The water for faucets and appliances comes from the hot layer on top.
Jul 28, 2015 | Water Water Heaters
How and where does the water go in
The cold water enters the top, but the water is not released into tank at the top. The cold water goes through a "dip tube" This takes the cold water to the bottom of the tank. If you dip tube fails, or breaks, your faucet temperature will slowly drop as you use hot water (vs giving you 60% of tank at full temperature before temperature starts dropping) In normal operation, the cold water is released near bottom of tank, the hot water rises to top, and comes out of the top of the tank.
Jan 27, 2015 | Water Water Heaters
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Were is cold water inlet and hot water outel on model 71-40d b
Cold inlet and hot outlet are marked on top of water heater.
Usually there is a letter or word embossed into the metal top.
If tank is connected, then turn on hot water tap for a few moment and feel which pipe is hot.
Cold water enters bottom of tank through dip tube located on cold side. If hot and cold are reversed, the water heater will not perform as expected.
http://waterheatertimer.org/Water-heater-dip-tube.html
Aug 05, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Low water pressure
Hi Bob,
You can determine if the tank is the problem by connecting a garden hose to the drain that is provided on most water heaters. Before doing this, be sure to shut of the electrical supply to the heater - otherwise you can damage heating elements if an electric type or waste fuel by heating an empty tank if a gas / propane fired type.
If you get a slow flow out of this drain, it means that somewhere in the cold water supply side to / in the tank - there is a problem. Inside the tank, the cold water is delivered by a "dip tube" that distributes the cold water to the bottom in the tank. Dip tubes are used in both electric and gas / propane fueled heaters. Here's a cut away view of a typical tank:
If the tube is clogged, or there is build up, scale or debris in the supply (cold water) side of the heater, flow rates will suffer. Likewise, if there is a problem with the output of the tank, it will directly affect flow as well.
If you get a good flow rate from the drain, then the issue is going to be on the hot water output side of the heater. Again, the same build up, scale, debris issues on the hot water out put pipe will cause problems with flow. Typcial tanks do not have dip tubes for the hot water side of the tank - as taking hot water from the top of the tank is most desireable and is furthest away from the cold water that rushes in to make up the hot hot water going out.
There's nothing really in the tank itself that can cause issues with flow outside of the dip tube, and piping to and from the tank.
Jun 29, 2012 | Water Heaters
Hello, I have a Bock Model 32E water heater (oil fired). When I take a shower, I have 10 minutes of really hot water and that is it. My water heater will not turn on while I am taking a shower and it...
This has to be one of two problems....
Either the dip tube is not in place properly or the hot and cold are reversed....
That is the ONLY way that you can be having that problem....
Make sure you have another person look at the heater...
Take off the piping on both the hot and cold lines and VERIFY that the dip tube is in place in the cold side, and that there is NO dip tube in the hot side....then also that the pipes are connected correctly...
heatman101
Apr 08, 2011 | RTO Bock Water Heaters 32E 32 gal 104,000...
My reliance natural gas water heater overheats causing scalding water to come out of my faucets. I have had authorized service companies come out three times to replace and retrofit different controls and...
Information below is for tank-type electric or gas heater only.
There is a condition called stacking.
This might apply to your water heater or not.
Having authorized service people to your house 3 times suggests more complicated mix of problems.
Stacking is caused when there are repeated short draws of hot water.
As you know, each time any hot water is drawn out of faucet, cold water immediately enters bottom of tank through the dip tube. The dip tube is connected to cold water inlet and runs to bottom of tank.
So all cold water enters bottom of tank close to the gas water heater thermostat.
See illustration of dip tube, that also shows copper thermostat sticking into tank that is connected to gas valve.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
Let's say your water heater if fully heated and burner is off.
A short draw of hot water causes cold water to enter tank.
Another short draw. And then another short draw, each draw happens close to same time as other draws.
Water at top of tank is plenty hot, but bursts of cold water get near thermostat and cause thermostat to turn on burner.
Burner heats water and more hot water rises to top of tank. Water at top of tank becomes overheated each time stacking occurs.
Again, a stacking situation may not be the cause of your problem.
However, remember if single-handled faucet is opened straight upward, then that draws both hot and cold water. And cold water immediately enters tank.
Only when the single-handled faucet is lifted with the handle all the way to the right, does it draw only cold water. Even so, some single-handled faucets have bleed-over between hot and cold sides, so hot water is drawn anyway.
Another possibility is that the dip tube ends at or near thermostat, instead of going all the way to bottom of tank. The dip tube should go straight down from cold water inlet, but dip tubes are made of plastic, and some self-cleaning tanks have a curved dip tube or dip tube with perforations that create currents designed to stir sediments off bottom of tank (although this is not proven to be effective deterrent to sediment formation).
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | RELIANCE ELECTRIC WATER HEATER
I have hot water for a minute then it goes to warm. I took off the 2 wires on each element and I have 15 ohms on the top and 5.5 on the bottom. Is my bottom element bad?
Sounds like bottom element may be bad but usually reads open circuit if bad. Also tan k would run about 8 gallons hot water then go cold. lots of warm water usually means bad dip tube.
Check if tank is hot at bottom element when not used for a while. If bottom element is still cold then bad element.
If bottom element is hot - (all water in tank is hot then you have a bad "dip tube" This is allowing incoming cold water to mix with outgoing hot water. The dip tube is usually A part of the cold water nipple or B located under the cold water inlet nipple.
Jan 18, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No water coming out of carver cascade water heater
is the cold side hooked to the cold side if not you will be feeding the unit backwars making it to where the cold is just comming across the top of the tank, check the dip tube also, this makes the cold water go to the bottom and push the hot out of its outlet,, how many faucets are involved, if just one might want to check the cartridge to make sure it is working properly
Jun 16, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
I have a Rinnai tankless. The temperature fluctuates wildly
I think the dip tube in your water heater has failed, this is a plastic tube that goes in the cold side of your tank and forces incoming cold water to the bottom of the tank allowing hot water out at the top. When this tube deteiorates the incoming cold water mixes at the top of the tank causing the problem you have. the dip tube runs about 5 bucks but takes someone with pluming skills to install.
Jan 05, 2009 | Rinnai Webstone The isolator EXP tankless...
Water Heaters Logo
121 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
