Drum will only turn with 1 or 2 items loaded anything else stays still
    Problem Solver:
  • 18 Answers
Sounds like the belt is slipping an inspection should determine the amount of grip, could be a cheap fix.
Posted on May 02, 2015
Drum won turn
Wow, check around the bellows, gray rubber seal in front between the stainless basket, remove any item. Didn't find anything now unplug unit remove top and lower machine covers. Run the flashlight along the outer tub while looking inside the stainless basket, locate any items that may jam rotation of the inner basket and remove.
Oct 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I have a LG WM1814CW front load washer. I get UE when it trys to go on spin cycle. I re-arranged the load and still comes up UE. I also tried a cycle without anything in the washer and still the same...
The UE error code is nothing to worry about. It indicates an "unbalanced error"¬-your washer's way of saying that the drum is not spinning is a smooth rotation. It could be as simple as rearranging the load in the drum (click image for zoom). Here's why:
1) Small loads. Your washer operates better when the weight of the load is evenly distributed across the drum, but that is not always possible with small loads.
2) Mixed fabric loads. For example, if you're washing jeans and t-shirts, the jeans could be on one side and the t-shirts on the other, causing the unbalance. Try rearranging the items and spin again.
3) Large single items. Items like sheets, blankets and comforters tend not to spread out evenly, causing unbalance when the drum spins. Rearrange the item and start the spin cycle over.
4) Spin Sense Option. If your washer has the Spin Sense Option, it may try to adjust the load on its own. If that happens, the washer would slow down and tumble a few times slowly during the spin cycle and then speed up until the problem is resolved.
Hope this helps.
Jun 24, 2011 | LG WM-2077C Front Load Washer
My washer model fjs1397w wont move through a wash cycle or spin drum wont go around on any cycle , tried moving it around by hand will not do anything
if you are unable to turn the drum by hand it may have ceased due to a sock or item of clothing jammed in it behind the drum this in turn may have snapped the belt
regards
Ian
Apr 20, 2011 | Zanussi FJS1225W Front Load Washer
My white night wont turn with full load,but if we lighten load it turns?
these are the items/parts:
1) belt may be stretched, examine belt for cracking and if it looking old replace
2) idler arm/pulley may be wore out, examine
3) drum rollers/glides may be wore out (second link)
4) motor may be going out
for the belt,idler arm/pulley and motor:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
drum roller/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jan 16, 2011 | Zanussi TD4100W Electric Dryer
The drum is not spinning and the machine stops and has LE on display
Sorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Jan 01, 2011 | LG Washing Machines
Error code LE
In new installations, this error can sometimes present because of a mis communication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
3 Thumbs - Helpful
3 Thumbs - Helpful
Dec 27, 2010 | LG WM1814CW Front Load Washer
The machine makes noise when it turns during washing
Check the surface of the inner drum for items that may be caught in drum holes. These items can produce noise while rubbing between the drum and tub. Clips, wires, etc. are all small enough to catch there and protrude from one of the holes. Carefully remove the item.
Nov 28, 2010 | LG WFT1071TP Top Load Washer
Creda drier drum will not rotate when fully loaded
The belt could be worn or bad or the tension spring is to loose and not keeping enough tension on the belt. When loaded to max belt just slips and doesn't turn the drum.
Dec 16, 2009 | Sewing Machines
The drum won't spin and belt will not stay on
i am sending you this breakdown, perhaps will help you to see if there is anything else broken or if you are missing a step in you installation of the belt. hope this helps.250
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
With only 1 item in Drum my new Bosch WAE24363 will not perform a spin cycle, yet adding more item into the drum then the machine will perform a full spin cycle. Why will the machine only do a full spin...
most modern machines have an out of balance detector to prevent the machine being damaged with a badly balanced load.
with a single item in drum, load will not balance and out of balance detector comes into action and prevents spin
Sep 09, 2008 | Bosch Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
