Question about Delta T13120-LTS Single Handle Monitor 13 Metal Multichoice Universal
How to turn on water outlets in delta bathtub?
I am not sure about the model number of the bathtub and shower system. The shower seems to be working fine. But the water outlets for the bathtub have some on/off controls but whatever I do, there is no water coming out from these outlets. Not sure what to do.
    Habit-Forming:
    New Friend:
  • 6 Answers
I've seen plugs they insert to outlets by the screens for some reason. But during a remodel I did I noticed those plugs and removed them. Or on a tub faucet the plug might be where you screw it onto waterline
Posted on May 02, 2015
When i hooked up a delta faucet for a handicap tub i had to put it on the right side of the wall so that the older guy could reach the handle to turn the water on and he wanted the shower head closer
Not usually, but there should be an inverter or other unit to activate the shower. Often it is in the tub outlet and blocks the tub outlet to force water up the shower pipes. If there is no such or if it is just not working you may need to run the piping up to a sufficient height and then back down to the shower head to create enough pressure resistance if it is as you say, requiring a specific height of pipe to get a specific back pressure. But there also needs to be a mechanism to force the water up the shower pipe. Look up Delta on the web and get a phone number as there will be someone at Delta that can fully advise you about this.
Oct 04, 2014 | Delta Home
I have a dual control shower valve. not sure but i think it is a delta around 8 years old. the temp valve has an O clip on the inside and two small set srews on both sides. how can i determine the model...
Most valves DO NOT have a model number. What you will need to do is remove the cartridge and take it to your local hardware store and they will match it up for you. WARNING please be sure to shut off the main water supply line to the house before removing cartridge. Some cartridges have their own water cut off screw buit into them.
Sep 14, 2011 | Home
I have a Delta scald guard shower faucet (older model). The cold water pressure is good but as a turn to hot the pressure drops to a drizzle. There are 2 other sinks and another shower upstairs and there...
It is more that likely the valve in the stem of your fixture, I'm assuming this is a single handle faucet. If you can replace the valve, you will cure your problem. I am giving you a link to how to adjust the hot water temp.
http://www.ehow.com/how_6531012_adjust-anti_scald-setting-delta-faucets.html
May 10, 2011 | Delta Home
Low water pressure from shower head with the shower head removed
If you have good pressure at the water faucet close to the shower and low at the shower then the shower valve needs rebuilt. If you have low pressure at all then start going down the line toward the water service coming into the house looking for where the low pressure starts in the distribution system and you should be able to isolate the problem.
Feb 08, 2011 | Delta Home
Delta shower faucet loses pressure when turned all the way on (hot water). What could cause this? When it first happened yesterday, a few tiny pieces of black plastic/rubber fell out of the bathtub...
Turn off the water to the home. You need tthe stem beneath the handle. Remove the handle after locating the set screw, remove the cylindrical beauty cover, and unthread the retaining nut to access the valve stem. Take it to a plumbing supply house or home store to make certain of the match.
Oct 06, 2010 | Delta & Single Handle Shower Faucet
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
May 29, 2010 | Delta & Single Handle Shower Faucet
Delta bathtub faucet
you need to stick large screw driver up in the faucet and turn it counter clockwise. this might sound ridiculous but it works.
Mar 26, 2010 | Delta & Single Handle Shower Faucet
Shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Nov 17, 2009 | Delta & Single Handle Shower Faucet
Delta T13120-LTS Single Handle Monitor 13 Metal Multichoice Universal Logo
345 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
