Question about Keurig Special Edition B60 Coffee Maker
It will not turn on. Is there a reset or some other option to try.
    Habit-Forming:
    New Friend:
  • 33 Answers
Make sure if your outlet has a reset button that it is pushed in, sometimes the circuit trip and the reset button needs to be pushed back in. Try a new outlet see if that helps.
Posted on May 04, 2015
Turn off subtitles on a Westinghouse LD 3265 tv? The cc button on the remote says"no cc information" & there is no option to turn it on or off.
Try a factory reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 18, 2015 | Westinghouse Televison & Video
When I try doing a hard reset. I can not get it to boot beyond the green Android guy. It shuts off or will not get me to the choice menu. Any suggestions?
On an android tablet of mine I have to hold the power and the volume (-) button down at the same time and keep holding them for about fifteen to twenty seconds until finally a menu with green text comes up. To select the text option I want, I have to scroll with the volume (+) button and when I'm on the right option I have to activate it using one short push of the power button.
The option I choose to do a hard reset is *wipe data/factory reset*. On my tablet, when I choose and activate this option it takes me to another screen with about six lines of *no no no* text and one line of the reset option. I have to scroll to the reset option using the volume(+) option and again use a short push of the power button to activate it. Then, it does it's thing and turns off. I then give it about ten seconds and then I hold the power button down for five or so seconds and it then it reboots to factory fresh condition. It takes a couple of minutes to get it done I guess because it's reloading all the apps, etc.
Mar 28, 2015 | Kocaso M1050
How can i reset factory setting on my sony dsc55 camera
Reset button on the camera
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Initialize or Reset option(s) in the camera menus
  • The menu layout is different between cameras so check the operating instructions.
  • In general, there will be a Reset or Initialize section within the menus of the camera.
  • Some cameras allow for resetting or initializing different options such as wireless settings, the settings used in taking the last picture, or all settings. Be sure to look at all available options in the product manual.
Manual reset process
Cameras manufactured prior to the year 2000 do not have reset buttons or options in the menus. Follow the steps below to reset:
    1. Turn off the camera.
    2. Remove the battery pack.
    3. Remove the button-sized lithium battery.
    4. Allow the camera to remain without power for 30 seconds.
    5. Reinsert the button-sized lithium battery.
    6. Reinsert the battery pack.
    7. Turn on the camera.
NOTE: If your camera is experiencing an issue and it is not resolved by performing the appropriate reset or initialize procedure above, service may be required.
Jan 06, 2015 | Sony Cyber-shot DSC-W55 Digital Camera
How do i reset a blu dash jr 4.0 k phone? model part is D142k
There should be an option to reset your phone in 'settings'.
Back Up and Reset should give you the option to reset with no problems. As you enter this option, the last option here is 'Factory Data Reset'. Try this and let me know what transpired after....
Dec 21, 2014 | Blu Dash Jr 4.0 K Cell Phone
How do I unlock my trio tablet! The code is a pattern and the tablet doesnt give me an option to retrieve the pattern or even reset it. Please help! Thx Kat
Some tablets will prompt you to reset after you have tried and failed entering the correct password a certain number of times. You can try this, it could work too.
Jun 26, 2014 | Tablets & eReaders
RESET Mitsubishi WD-65837
The set aside from a reset button recessed on front (some do and some do not) has at least 2 hidden menus= adjustment and OPTION MENU---option menu will do a hard reset of the entire set---but it requires a 4 digit number code by model---being 1500 miles away from my paper files I have a suggestion.
You can search to see if can find (I strongly doubt Mitsubishi will tell you) the entry code for your model.
Some of these sets also had a soft reset (no harm trying) and it is with the set turned on and using the Mitsubishi remote (also needed for hard reset) Menu, 1,2,3 enter.
That ought to be at least tried and the OPTION menu is usually last resort here---
SD TECH
Apr 19, 2012 | Mitsubishi WD 65837 TV
I need a reset ...
Do a manual reset: remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on. However, this blue picture problem doesn't sound like a reset will fix it.
Feb 03, 2010 | Olympus EVOLT E-500 Digital Camera
Lens stuck outside. Sometimes says "access" on lcd.
Try these troubleshooting steps and check if it help to resolve it.
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
1. Press the Menu button on the Camera.
2. Then, select the SETUP menu and select the SETUP 1 option of the Camera.
3. Then, select the Initialize option to OK.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
If the issue still persists then Service may requires to resolve it.
Aug 31, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Can't turn off Vista Master Password for the software security device
Removing your master password
  • Firefox 1.5: "Tools -> Options -> Privacy -> Passwords -> Remove Master Password"
  • Firefox 2.0: "Tools -> Options -> Security -> Passwords -> Uncheck "Use a master password". You will be prompted for your Master Password.
  • Thunderbird: "Tools -> Options -> Privacy -> Passwords -> Remove Master Password"
If you have lost or forgotten your Master Password or you want to disable the feature, you can reset your master password. Upon resetting, you will lose all the stored information in the Password Manager as this is a built-in security feature to prevent people from simply resetting your Master Password to gaining access to your passwords.
For Firefox you can also look at the Troubleshooting section in Password Manager.
  • Firefox: Enter "chrome://pippki/content/resetpassword.xul" in the Location Bar, press Enter, then click "Reset"
  • Thunderbird 1.5: "Tools -> Options -> Advanced -> Saved Passwords -> Master Password -> Reset Password".
  • Thunderbird 2: Choose Tools – Error Console, paste the expression: openDialog("chrome://pippki/content/resetpassword.xul") and press the Evaluate button. That will open a dialog asking you if you want to reset your password.
  • For Mozilla Suite: "Edit -> Preferences -> Privacy & Security -> Master Passwords -> Reset Password".
Taken From MozillaZine, http://kb.mozillazine.org/Master_password
SM
Apr 04, 2008 | Microsoft Windows Vista Ultimate Edition
Keurig Special Edition B60 Coffee Maker Logo
205 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
