Question about Dynex Televison & Video
I am unable to power on this TV through the remote or TV power button. Do not get a green light for power. Should I look for replacing a power supply cord or the power unit within the TV?
Dynex DX-TDVD19-09. Now power with remote control or using power button on TV.
  • Dynex Master
  • 670 Answers
Hi Liz, You are not getting The green light means either the power ie AC is not reaching the TV or the power supply section inside the TV has broken down. Your guess is right about the power cord and the power unit within the TV.The Problem will be there within your guess. But I think you will need the help of a good technician to isolate the fault and rectify it. Good luck.
Posted on May 02, 2015
Program code for Directtv Universal remote.
You can see an easy step-by-step guide to programming your remote right on your TV screen:
sm_cl_blu__number1_icon.pngPress MENU on your remote control sm_cl_blu__number2_icon.pngSelect Settings & Help sm_cl_blu__number3_icon.pngSelect Settings sm_cl_blu__number4_icon.pngSelect Remote Control sm_cl_blu__number5_icon.pngSelect Program Remote and follow the on-screen prompts img_remote_control_tv_sol1.jpg You can also use the manual method below: sm_cl_blu__number1_icon.pngMake sure your TV and your receiver are both on. sm_cl_blu__number2_icon.pngUse this tool to look up the 5-digit code for your TV. There could be more than one code for your brand of TV. sm_cl_blu__number3_icon.pngSlide the MODE switch on your remote control to the TV position. sm_cl_blu__number4_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number5_icon.pngUsing the number buttons, enter the 5 digit code for your brand of TV. The green light under the TV should flash twice. sm_cl_blu__number6_icon.pngAim the remote at your TV and press the VOLUME UP button. If the volume doesn't increase, repeat Steps 3-5, trying a different 5-digit code for your TV. If your remote control fails to program using all available codes, try scanning for additional codes. If one of the codes worked, proceed to the next step. sm_cl_blu__number7_icon.pngPress and hold MUTE and SELECT buttons until the green light at the top of your remote control flashes twice. sm_cl_blu__number8_icon.pngEnter 9-6-0 using the keypad on the remote control. The green light should flash twice again. sm_cl_blu__number9_icon.pngSlide the MODE switch on your remote control to the DIRECTV position. img_remote_control_tv_sol2.jpg Follow these steps to scan for additional TV codes using your DIRECTV remote: sm_cl_blu__number1_icon.pngSlide the MODE switch on your remote control all the way to the right to the TV position. sm_cl_blu__number2_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number3_icon.pngUsing the number buttons, enter 9-9-1. The green light on your remote should flash twice. sm_cl_blu__number4_icon.pngAim the remote at your TV and press CHAN/PAGE UP button. Tap the CHAN/PAGE UP button repeatedly until the TV powers off. sm_cl_blu__number5_icon.pngWhen the TV powers off, press and release the SELECT button. Note: If the green light flashes three times before your TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, but your TV may not be compatible with our remote control.
Jul 08, 2014 | GE JASRM24912 Remote Control
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
How can i set up my direct tv remote to my Haier tv
How to scan for TV codes on your DIRECTV remote
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9-9-1, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
Feb 13, 2013 | Haier HL22XLE2 - HL22XLE2 22 LED-LCD TV -...
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
Then enter 9911, the green light on remote should flash twice.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Mar 08, 2010 | Televison & Video
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Mar 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
166 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
