Question about HP PhotoSmart Office Equipment & Supplies
Error light and power light flashing together
  • Calvin Bruce
    Calvin Bruce May 12, 2015
    I sent in a video of the flashing light. Message on the printer utility under Device Status says "Door/Cover is open." But it isn't. What am I missing?
    Novelist:
  • 175 Answers
What model? D110? 8110?
Try turning off the printer, clearing the print queue, restarting the computer, then turn the printer on.
If that doesn't work, what happens if you turn off the printer, disconnect it from the computer and then turn it on?
Posted on May 04, 2015
Testimonial: "As soon as I turn it on, it cycles through its setup and then the lights start flashing, whether attached to computer or not. If attached to computer,the printer utility says the Door/Cover is open. So maybe some sensor that thinks the Cover is open, but it isn't and I don't know where to find or fix it."
  • fixya62589 May 12, 2015
    Check this advice from HP: "Open the Access Door approximately 1 inch (2.54cm), and then allow the Access Door to drop. If the printer continues to sense the Access Door is open then service the unit."http://support.hp.com/us-en/document/c01...
    Do you have a Photosmart 5160? That model seems to have this problem frequently.
We have a Mitsubishi TV model# WD-60735.. we have changed the lamp because it was flashing red but now its flashing yellow and the tv will not turn on..
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 18, 2015 | Mitsubishi Televison & Video
Sharp Aquos LC46D82U Power & OPC blink together once, then Power twice alone. Where can I find the error codes to fix this?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 22, 2014 | Sharp Aquos Televison & Video
Why does my Sony kds-50a2020 power light flash 6 times?
I would talk to whoever rebuilt the optical block and see if they have any suggestions. It could be that the rebuilt unit is causing the problem.
Jul 20, 2014 | Sony KDS-50A2020 Television
Flashing light mean yellow
Jan 15, 2014 | Mitsubishi WD-60737 60 in. HDTV
Starting light flashes green, and then red. Turn off and on several times.
Possible lamp but:
Nov 07, 2012 | Mitsubishi WD-65733 65" HDTV
Wd-60737 mitsubishi blinking yellow status light ?
Oct 25, 2012 | Mitsubishi WD-60737 TV
Green light on tv trunes tv off. then green light gose off @ ON
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 17, 2012 | Televison & Video
Flashing battery life lights, quickie 525s
The chair is either in freewheel or the number of flashes will indicate an error code to tell what the problem is. Look in your users manual for error codes or contact Sunrise Medical Tech support
Jul 23, 2010 | Quickie Wheelchairs Quickie Aspire Power...
The heated dry and clean lights flash together
I had this same problem. I read on another blog that the manual recommends that you turn the power off to dishwasher. When you turn the washer back on, the lights still flash but then push the off button. The lights stopped flashing.
Jan 15, 2009 | Maytag 24 in. DWD1500A Built-in Dishwasher
47 people viewed this question
Seeker5211
Seeker5211
