Question about Irulu 10.1 inch Android 4.0 Touchscreen Tablet PC Support MID Google 3G WiFi Network & Bulit-in 1GB DDR3 8GB Nand Flash With RJ-45 Connector for Ethernet/ ADSL
Battery not charger - Irulu 10.1 inch Android 4.0 Touchscreen Tablet PC Support MID Google 3G WiFi Network & Bulit-in 1GB DDR3 8GB Nand Flash With RJ-45 Connector for Ethernet/ ADSL
    Sergeant:
    Champion:
  • 253 Answers
Maybe the charger is bad, try to check it
Posted on May 02, 2015
My Tablet is on charge and the screen icon shows it is charging but the Charge % Icon is staying the same
Try a different battery charger.
Maybe you are using a battery charger of a phone.
They have the same plug but different Amperage.
Usually tablets have more powerful battery charger than phones (2.1A instead of 0.5/1A).
The battery charger that you are currently using seems to have enough power just to keep your tablet alive, but not enough to charge it.
You can check on the data written on the battery charger's body the maximum amperage.
Jul 16, 2016 | Amazon Kindle Fire HDX 7
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
May 11, 2015 | Tablets & eReaders
My RCA tablet won't turn on and will not charge, what can I do?
If battery is depleted, then no, it will not turn on.
If battery charger is dead, phone won't charge or turn on.
If battery charger cable is broken, tablet won't charge or turn on.
You need to ensure you have a good working charger, and a good cable. Only a known good charger and a known good cable can charge the unit. Borrow or invest in a new charger and cable (they're cheap on eBay).
Only once you know the charger and cable are good can you determine that they are not the problem.
Depending on how old the unit is, it's possible the battery can no longer hold a charge and needs to be replaced. You won't know that though until you first determine the charger and cable you're using are working properly and providing a good charge.
May 07, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
My tablet will not turn on
Try plugging it into the charger for a few minutes and turn it on with the charger plugged in, if it still does not turn on ensure the charger is ok, if so the battery may be fully discharged and may need replacing. if the battery and charger are both fine, check contacts to the battery and pcb as well as charging socket. if all ok there is an issue with the board.
Jan 22, 2015 | Tablets & eReaders
Why the battery conot charge?
Either you have a bad battery or the charger is not putting out the correct voltage to charge it. Check the output of the charger, if its OK, the batery is bad.
Nov 05, 2014 | Coby kyros Tablets & eReaders
Tablet charger is 400mAh and Tablet battery is 4000mAh. is my charger sufficient ?
The charger is right for the battery. IF battery won't charge on it proper charger, the battery or charger is bad. Take it back or put out more $$$$$$$$$.
Aug 31, 2014 | Tablets & eReaders
Battery not charging
Are you using the charger that came with the tablet? If you are using a cell phone charger...it will not work. The tablet charger is rated for 2.1 A. Most cell phone chargers are rated for less than 1 A.
Mar 30, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
My zeepad 7.0 battery is dead
Hi, Zeepad battery is PBS01SHz10 is a japanese battery, similar to nokia BL-5k battery.
Open a zeepad is easy, the problem to find these kind of battery. I am thinking in change the internal connector to adapt the nokia n86 battery, is more easy to find almost here in Venezuela.
Apr 03, 2013 | ZEEPAD VIA8650 Android 2.3 Tablet
MotorOLA XOOM battery won't charge
Keri
Maybe a bad charger.
Mark
Motorola Support
Mar 15, 2012 | Motorola Mobility Xoom
Irulu 10.1 inch Android 4.0 Touchscreen Tablet PC Support MID Google 3G WiFi Network & Bulit-in 1GB DDR3 8GB Nand Flash With RJ-45 Connector for Ethernet/ ADSL Logo
52 people viewed this question
Top Irulu Tablets & eReaders Experts
David Clark
David Clark
john smith
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
