Question about Kelvinator Refrigerators
I mistakenly pushed the defrost button. How can I stop defrosting?
  • Kelvinator Master
  • 5,323 Answers
It should normally come out of defrost mode after bout half hour but u can manually take out also.
May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section.
u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
I mistakenly pushed the defrost button. How can I  - mistakenly-push-defrost-button-plz-tell-iizpua1124tc1voeqjalmrl5-3-0.jpg
Posted on May 07, 2015
When i press defrost button it stucks inside it, is it normal???
Hi
If it is a manual defrost fridge with a push button defrost then yes the button stays in until it has finished the defrost cycle.
But as no model & make have been provided this is just a in principle answer.
Bryan
Apr 29, 2015 | Refrigerators
Keep Runing All The Time Never Stop.
Check the thermostat control to minimum, if still making ice freeze then it is defective.
Check the defrost push the button if doesn't defrost it is defective.
Replace defective parts with the same ratings and size.
I hope I give you idea for your freezer problem.
Jun 28, 2011 | Continental Freezer Wide...
How do you manualy defrost?
Defrost the refrigerator when the frost accumulated on the evaporator is about 1/4" thick. To defrost, simply push the defrost button. Be sure to keep the drain pan in place. Defrosting usually takes a few hours. The refrigerator will restart automatically when defrosting ends. Empty water from the drain pan after defrosting.
Jun 18, 2011 | Magic Chef MCBR445W1 Compact Refrigerator
How do you activate the flash defrost function on a Kenmore 16082 model? I can't find any flash defrost button.
Hi
Not all these models were fitted with a flash defrost plunger, if fitted it is inside the lid on the left hand side.
You will need to remove all the product from the freezer and store it elsewhere.
1. Pull out the flash defrost button
2. Put a chock of wood or similar to prevent the lid from closing (if the lid closes it will stop the flash defrost)
3. Wait until all the ice has melted then clean out the casing, some of these models have a drain plug in the base, (put a shallow tray under the outlet to catch the water) others you will need to mop out the water.
4. Push in the flash defrost button and wait for a couple of hours and then you can reload the freezer.
If there is no flash defrost button then follow the above instructions after you have emptied the freezer, all you need to do is switch off and unplug the freezer then go to 2. above. When finished plug back in and reload.
Regards
Gordon
May 05, 2011 | Kenmore Chest Freezer 16082
How do i defrost my 4.cu ft manual defrost fridge?
Turn it off or unplug it, put a big towel inside to catch the water, afterward, wipe off the water and turn it back on. Some manual defrost fridge has a defrost button, you can push it once and it will defrost it for you.
Mar 07, 2010 | Refrigerators
What is the button in the middle of the temp gage? My refrigerator always seems to be too cold.
It is a defrost button. Defrost the refrigerator when the frost accumulated on the evaporator is about 1/4" thick. To defrost push the defrost button. Be sure to keep the drain pan in place. Defrosting usually takes a few hours. The refrigerator will restart when defrosting ends. Empty water from the drain pan after defrosting. (taken directly out of owners manual)
Jan 28, 2010 | Magic Chef MCBR440 Compact Refrigerator
Whats the push in button in the center of temp. conrtol knob, on the dorm size model?
On this model, the push button in the center of the temperature control is for starting a manual defrost cycle.
If you see ice building up on the evaporator (the freezer section), you just push the button and the fridge will stop the cooling cycle and initiate a defrost cycle to melt the ice.
The unit will automatically start cooling after the pre-determined defrost cycle time has elapsed.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Magic Chef Refrigerators
Atlas frost refrigerator
Push in the red "Defrost Button" located in the center of the temperature control dial. Defrost cycle will start immediately. NOTE: Turning the temperature control dial to the OFF position is not required. Defrosting usually takes a few hours. When defrosting is complete, the red "Defrost Button" will release automatically. Then the refrigerator will resume normal operation while moving towards the set temperature. NOTE: After defrosting, allow a few hours to reach the set temperature before making any further adjustments.
Dec 30, 2007 | Atlas Refrigerators
Refrigerators Logo
107 people viewed this question
Top Kelvinator Refrigerators Experts
John Tripp
John Tripp
billconfused
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
