Question about Cooktops
How do I replace the igniter on a Verona cook top?
    Producer:
    Uploaded 30 video answers.
  • 59 Answers
Hello i think it will help you
Posted on Jul 11, 2015
2 Suggested Answers
  • 500 Answers
SOURCE: Brand new Verona Gas cook-top
Hi jason_rafins,
The ignitors might just have gotten wet, not a big deal, they just need to be dried.
Please follow my directions on the Tip below on how to do this:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Posted on Aug 17, 2011
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
I just installled a Verona VEFSGE 365 dual fuel range/oven.
Got to your manufacturers instructions and check if you have a auto cook timer for the ovens, if so normally the timer needs to be set on "Manual" to enable it to function.
Apr 29, 2013 | Verona VEFSGE365DAW 36" Double Oven Dual...
No gas coming out from all hobs
Do you have a drop down lid over the burners, if so the mechanism may be faulty. Most of this type of design has a safety cut off when the lid is shut, and it won't allow gas to flow through to the hob, lift the lid and check behind and see if it has stuck closed.
Apr 28, 2013 | Verona 34 in. CTG536S Gas Cooktop
Brand new Verona Gas cook-top just installed the ignition is permanently on. Is there something I am missing on how to turn it off?
Hi jason_rafins,
Kind Regards
JEDEMEYER1
Aug 17, 2011 | Cooktops
I was cleanning my 24" stainless gas cook top when all of the sodden a clicking sound from the pilot doesnt stop what do I do?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Sep 18, 2010 | Verona 11 in. CTG212F Gas Cooktop
We have an older corning cook top and it seems to burn or stain very easily. What is the best cleaner to use without scratching the surface.
I use a razor blade scraper to remove the heaviest deposits and then scrub it clean with Bar Keeper Friend cleaner.
Aug 08, 2010 | Verona 34 in. CTG536S Gas Cooktop
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 | Cooktops
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Does not ignite
Check to make sure that the gas is getting to the igniter. If you can ignite with a lighter or match, than the igniter itself needs to be replaced.
Apr 01, 2009 | GE 30 in. JGP326 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Cooktops Logo
207 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
