Question about HP Scanjet G2710 Flatbed Scanner
Why does the scanner stop half way? - HP Scanjet G2710 Flatbed Scanner
    Scholar:
    New Friend:
  • HP Expert
  • 52 Answers
Hi kenneth Ssali,
I wonder if the scanner bulb is not getting enough power to heat up and function properly. Do you have the printer connected directly to a wall outlet or is it in a surge protector or power bar? Even if you have been using a surge protector/power bar all this time and you feel it is not the cause, please connect it to a wall outlet just so we can eliminate the power source as the root cause. Issues when Connected to an Uninterruptible Power Supply/Power Strip/Surge Protector In this document you will see, ISSUE: Problems or issues may arise when an HP LaserJet series printer is connected to an uninterruptible power supply (UPS), a power strip, or a surge protector
^ This is not limited to Laserjet printers.
If you have not done so already, I suggest trying a hard reset. To do so, leave the printer on and unplug the power cable for 1 minute. While it is unplugged, hold down the power button on the printer for 10-15 seconds to release any built up power, then after the minute has passed, plug the printer back in.
If the issue persists, please let me know if you are seeing an error of any sort on the scanner or computer, perhaps the issue is related to the software instead.
I look forward to hearing back from you. I work on behalf of HP.
Posted on Jul 09, 2015
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Half way through scanning a neg scanner stopped working flashing red light came on
Some type of error has acurred. It may be that your orientation with the file is incorrect .turn your original try again.
Dec 02, 2015 | Epson Office Equipment & Supplies
My Epson 1240 has just stopped scanning the bottom half of the flatbed. It makes a crunching noise and goes back to the top.
The Track/chain that the scanner bar follows might have some debris/dirt whatever on it stoping it from moving further. Alternatively the motor might have a problem. you can take the cover off and blow that area with a con o' air. Make sure not to get dirt or prints on the scanner or the bottom of the glass
25630969-kdbydlvhgx3mczs4yctz3wk3-5-0.jpg Basic idea of most scanners
Apr 06, 2015 | Epson Perfection 1240U Flatbed Scanner
HP 1160 e cuts off side of page. How do I fix this?
Printing or paper?.. If printing check 1. check with another cartridge 2. check half test page(half test page while printing half page stop printer remove cartridge & paper see the image created on cartridge drum or not ,if not clean the Laser scanner assm, check on paper proper image or not if not clean the transfer roller.(looked like sponge roller located just under the cartridge location). beyond this trouble shoot, advised to send it to service center..
Sep 13, 2011 | HP LaserJet 1160 Printer
Hp scanjet G2710 scanner isnt scanning the whole document.the light only moves half way then stops
If you are scanning via software then the software could be looking for a smaller image. Check the preview and adjust the size as necessary.
Apr 30, 2009 | Office Equipment & Supplies
MESSAGE TO PUT FILM IN SCANNER WHEN SLIDE IS IN SCANNER
I had exactly the same symptoms and it was solved by using the screw on the stepper motor as described in:
http://www.pcreview.co.uk/forums/thread-1936922.php
You have to take the two metal covers off and then the plastic front, to reveal the motor. Use a screwdriver to move the carriage back and forward by a cm or so, leaving it near the front again, but not tightly - say half a turn away from the end-stop.
Good luck
Feb 09, 2009 | Nikon LS 2000 Film Scanner
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Won't stop scanning
L16 Disc coil needs adjustment, Audio is slightly off, and improper noise to DC squelch level detect used to stop scan on active channel. Set to an on freq signal like a NOAA weather channel, and useing a non-metallic tool, adjust to best sounding audio, probably less than a half turn either direction. An on freq signal moduated by 1000hertz, connect scope to speaker and adjust for highest undistorted recovered audio would be better if you could.
Dec 31, 2008 | Radio Communications
Scanner will not work
better you go for a new one
Aug 06, 2008 | HP ScanJet 2400 Flatbed Scanner
HP Scanjet G2710 Flatbed Scanner Logo
111 people viewed this question
Seeker5211
Seeker5211
