Question about Riverdeep The Print Shop Deluxe 15 [OLD VERSION]
I have Windows 7 64 bit on my laptop and had Print Shop v15 functioning perfectly, but after a bug was removed I could not reinstall PS v 15 again. What's wrong?
It seems the anti virus programs on my laptop are rejecting PS.
    New Friend:
  • 6 Answers
I feel that the PS v 15 software that you installed has some virus in it. So your antivirus deleted that file which has virus in it. So your software stopped working without that file which has virus. So try to get another PS v 15 software and try to reinstall it.
Thank you
Posted on May 12, 2015
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
Hi I have a Windows 7 (64 Bit) laptop and im
Please check the driver weather its support Win 7 64-bit or not, because Win7 have 2 varians 32-bit and 64-bit. If its not support 64-bit windows, you can download new driver but must be compatible with 64-bit system. Even if its the latest version of driver, but not support 64-bit system it won't be work.
You can download driver from here :
http://software.canon-europe.com/products/0010891.asp
or here :
http://driverscollection.com/?H=PIXMA%20MG6150&By=Canon (choose Windows 7 64-bit).
Uninstall the driver from your PC then reinstall with the new driver.
Hope this help.
Mar 09, 2011 | Canon PIXMA All-In-One Photo Printer with...
I've installed Print Workshop 2009 and...
Not enough memory to handle this type of graphics. I recommend at least 1.5GB memory. Other experts may suggest 2GB or 4GB .... Add a single 1GB memory stick to what you have. You may have to remove one stick to install this. If you plan on greater graphics, then 2GB is what you need.
Also, If you have Symantec/Norton antivirus, I suggest you uninstall it if your license is nearly expired... switch to FREE AVG by Grissoft. It will not cause your laptop to slow down when you need it the most!
(Un-install password for Symantec products is: symantec)
Sep 22, 2009 | ValuSoft Print Workshop 2009 Full Version...
Bug behind plastic screen cover and loose right side movement
Sadly the entire system needs to be taken apart. There is going to be at least 15 screws to remove and you need to move with surgical precision.
Thanks, Frank
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 14, 2009 | HP Mini 1035NR Notebook
Why wont wizard uninstall print shop 15
Dear the uninstall wizard is basically a program to remove the files of a specific software from the system, the uninstalled wizard is disturbed, thats why is unable to uninstall print shop 15. You need to reinstall it in order to make corrections to the uninstall wizard. or need to install the operating system again.
Best regards.
May 18, 2009 | Computers & Internet
Can't print with hp deskjet 3325
delete all of the hp software, reboot windows, remove anything in "add remove programs" that looks like it belongs to HP, reboot again, then plug in printer wait for it to detect it, then reinstall software.
t
Nov 18, 2008 | Computers & Internet
Acer Aspire 3684 nwxi
Have you tried booting into safe mode? If not, hit F8 at startup (before the Windows logo) and see if safe mode works. If you can get into safe mode and not normal mode, you have either a) driver problem or b) Windows corruption
If that is the case, you can remove your drivers from your device manager (video and audio drivers are the biggest culprits) and try booting normally again. If the drivers are the problem, windows will boot and try to load drivers for the devices that you removed.
If you end up removing all devices and Windows still won't boot, you either have spyware or viruses on your system ... or Windows is so corrupted that you will need to reinstall.
Be aware that if you have bugs in your system, a simple "Windows repair" might not work. You can try it, but just be aware. Worst case scenario, boot into safe mode again, back up your files to a flash drive, external drive or another partition, then reinstall Windows "clean", which will wipe the C drive and reload a clean install with no bugs and no problems :)
Good luck - hope it helps!
Sep 29, 2008 | Acer Aspire 3680 Laptop
Riverdeep The Print Shop Deluxe 15 [OLD VERSION] Logo
Top Riverdeep Computers & Internet Experts
Bosse Photos
ray gallant
Are you a Riverdeep Computer and Internet Expert? Answer questions, earn points and help others
