Question about Microwave Ovens
Why does the panel read -F3- and the oven won't work?
    Master:
  • 371 Answers
Problem with the control board. You can try removing and cleaning it. Might get another few months out of it. Good luck!
Posted on May 02, 2015
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: I have a GE microwave.
F3 means that your keypad is shorting.
If you'd like to have us fix it for you, we do that for $39.95 plus parts. We repair them for customers nationwide.
Or if you want to do it yourself, please contact me directly and I'll give you details on parts and procedure.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 27, 2008
  • 373 Answers
SOURCE: microwave quit
I dont know if this is going to work but qhat the heck do you have to lose
unplug it for a few min. then plug it back in
Posted on Feb 10, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave fan started and f3 shows on the screen the only was to
> JVM1440WH04
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X10951 and you can get it here for $93.20 (compared to $137.25 from GE!).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The you unplug the keypad (as per the attached photo) and move the circuit board into your frame.
Posted on Jul 20, 2009
HOTPOINT COUNTERSAVER PLUS RVM 1435 DISPLAY READS F3
"F3" on a GE / Hotpoint microwave means you have a shorted membrane keypad.
On RVM1435-series microwaves, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number (RVM1435XX###) from the tag on the oven here.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Nov 23, 2011 | Hotpoint RVM1435 Microwave Oven
Hi, We have an error code that will not allow our oven to work. F3 keeps displaying on the oven panel. F0 pops up as well.
F0 - Shorted push pad / Replace
F3 - Shorted or open oven temperature sensor / Replace oven temperature sensor
Good luck.
Apr 28, 2011 | Microwave Ovens
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
Spacemaker Microwave Oven
F3 means shorted key panel. You get prompted with F3 error if a short on key panel is detected for over 60 seconds.
Test key panel wiring and eventually replace key panel.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | GE Spacemaker JVM1750 Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
prototech@usa.net
May 29, 2006 | GE JVM1861SF Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
