Question about Troy Garden
Why is oil coming out of the muffler when I try to crank a Troy Bilt 4.0 edger?
    Master:
  • 371 Answers
Dit it get overturned? Sit it upright, pull out the plug, spray carb cleaner inside, pull repeatedly to clear oil. Ground the coil wire while pulling or you will ignite the carb cleaner- POOF!
Posted on May 03, 2015
    Top Expert:
  • Troy Master
  • 42,795 Answers
If it is a 4 stroke engine then the sump is over full
if it is a 2 stroke engine then the oil in the fuel is at the wrong ratio and is not burning but is forming the the muffler and running out
  • 7 Answers
SOURCE: troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Posted on Nov 10, 2009
  • 242 Answers
SOURCE: starts and then shut off Troy bilt edger
clean out carb and run gas cleaner throught the tank
Posted on Dec 28, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My Troy-bilt edger C5 4-cylinder will not start.
Check your fuel filter in the fuel tank to make sure it is clean if it is then"
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
mwoodring1
  • 496 Answers
SOURCE: how to replace belt on troy bilt edger model
can you send me the Serial Number and i can get you the manual on pdf file for you to download free.
M.Woodring
Posted on May 29, 2011
canwoodjc
  • 3301 Answers
SOURCE: how often should I change the oil in my Troy Bilt
every 30 hours of use, and 5w-30 is fine
Posted on Jul 14, 2011
Troy-bilt TB525ET 4 cycle??
no you do not mix gas but there is a type of oil that goes in the back of your engine called the houle and im not sure if its 4 meaning regular oil or 2cycle im thinking its 2 because as the engine runs it mixes on its own to create a so called 4 cycle which to everone ive talked to on the outside is a week engine im being told that 2cycle engine has alot more tourque if you want to get a job done quick and it look good
Feb 21, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What kind of oil goes in crankcase
Rule of thumb for lawn and garden equipment ...
If it is 2 cycle - gas and oil are mixed - 50 to 1 mix. Some two cycle engines require more oil ... up to 32 to one.
It if is 4 cycle - has a fuel tank and a crank case - 30 weight oil SJ or better service rating.
If you want to become an expert on oil ... go here: http://www.bsehome.net/pdf/OIL_S_EG.PDF
And a final word ... it is always good to refer to the manufacturer recommendations when selecting lubricants. Troy Bilt (no longer manufactured by the Troy Bilt Company in Troy New York) uses a number of different engines on their procducts. Here is a link for you: http://www.troybilt.com/webapp/wcs/stores/servlet/category2_10001_14102_54971_54970_54970_-1?cm_mmc=Google-_-WG-_-Tillers-_-Sponsored
Thanks for using FixYa.com
Mar 22, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
I put to much oil in my weed eater, lot of blue smoke came out, then it stopped. if i pour some of the oil out and let it cool off will it be ok
should be ok drain oil to correct level remove spark plug clean and dry plug,with plug out crank over to remove oil from cylender,make sure air filter did not get oil soaked if dry reinstall if wet replace. reinstall spark plug and start probably will smoke untill it burns off residual oil in muffler hope this helps
Aug 09, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Ive got a troy-bilt gas trimmer tb25cs it has always ran perfect,until now when i start it up aqnd give it gas it stops running and leaks gas
Check and clean your spark arrestor located behind a diverter plate on outside of muffler. You'll need a #25 Torx, or one slot screwdriver and wrench to take the plate off. Clean it with carb cleaner and wire brush and re-install. If this screen gets clogged, it could lead to fuel spray coming out of carb throat. Clean and re-oil the sponge filter while you're at it. Hope it helps!
Mar 24, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy-bilt gas edger trencher won't start. Spark
Oct 25, 2009 | Garden
I am able to crank the trimmer but it does not stay on. in the past it worked just fine but sat unused for roughly 4 months and now this. we own a TB425cs string trimmer. how do i fix this issue?
1) Change out the old fuel (not just adding fresh but pouring out the old and replacing it entirely) and check the engine oil.
2) Check muffler and/or spark arrestor screen for restrictions.
3) Clean and reinstall spark plug (check gap).
4) Replace inlet screen INSIDE the carb. (It is located directly under the inlet needle.)
Try each of these as needed.
Hope this helps!
Oct 01, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Rough idel and no throttle on a Troy -bilt BT25ET
It sounds like you have done everything but replaced the fuel filter. Which is usually located in the fuel tank. And clean the muffler. You will probably find some oil and carbine build up.
good luck
Aug 07, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
How to replace air filter on Troy-bilt TB20CS?
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
www.stollerlawnandgarden.com/.
Click on parts lookup in left hand column.
Jun 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy built cultivator will only idle 26cc 5yrs old
Problably not sucking air, but not getting enough air. Does your cultivator use gas/oil mix or straight gas? If it is a gas/oil mix the muffler is probably stopped up with carbon and cutting off the air flow. Try removing the muffler and see if it runs better.
Jun 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Garden Logo
57 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
