Question about Welding Tools
Why won't a 30A air-cooled spool gun feed wire?
  • 52 Answers
Could be the welder, the gun motor, the wiring, ect. Does the drive roll turn without any pressure?
Posted on Jul 20, 2015
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
  • 225 Answers
SOURCE: wire broken off inside of liner in mig gun hose
about the only thing to do is take the gun of the unit ,place it straight in line on the floor or bench and try to hand feed the wire back the other way.good luck,this will be a lucky thing if it works.i dont understand how the wire broke off in the first place.
Posted on Aug 02, 2009
  • 8 Answers
SOURCE: Not sure how to connect the magnum sg spool gun
Needs to be in dcep, or reverse polarity to weld aluminum
Posted on Aug 12, 2009
  • 850 Answers
SOURCE: wire feed not working wire feeds through the
Does it have a feed adjuster ? its like a clamp over the wheel that applie pressure to the wire in order to push it through the line!
always deburr the line when feeding it into the tube!!
cheers rob
Posted on Aug 15, 2009
SOURCE: When I press on the welding gun trigger the wire
Sounds like the wire driver circuit, or drive or motor is faulty. Probably a blow driver transistor or chip. But may be a motor brushes if it has any?
Posted on Feb 15, 2010
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    When I push the trigger I lose my voltage to run the feed motor, the motor works with other power source
    Had the same problem with mine but mine isn't miller and don't know if your's is built the same but if you access the inside of the machine there's there's a large copper spool inside and that wire feed handle is powered through it. The connection heats up over time and becomes a short. I re spliced mine then soldered it and then cut piece of copper tubing and crimped it around the connection and soldered that as well.
    Corrected the problem and I tried pretty much all listed solutions other then this first. Tried the new liner in the torch, the new tip and clamping the wire feed assembly with a clamp instead of the tensioner. All failed. I stumbled on to the fix accidentally when I was trying to install a more heavy duty fan. Hope this helps. Good luck.
    Apr 21, 2016 | Miller Spoolmatic 30a Mig Spool Gun 130831
    My wir burns up at the feed wheel before it goes to the sleve
    did you forget to reverse the wire .seems like I read that someplace . many newer ones thay added a switch for that purpose .
    May 07, 2015 | Miller Spoolmatic 30a Mig Spool Gun 130831
    On a 30A air cooled spool gun, why is the wire feed motor not turning?
    What machine is it hooked to. Could be the gun or the machine, or the cable between them.
    May 02, 2015 | Welding Tools
    Miller spoolmatic pro 30A, It still feeds, but won't arc. Less than a year old, what can I try?
    Run the first layer of wire of the spool you will see a color change. The wire gets a fine layer of oxidation and this causes a bad contact.
    Why wont the wire come through my cosmo gas gasless welder
    Most mig welders have reversible feed spools. There is a good chance you have the spool in the .030 wire side. Remove the spool retaining clip and flip the spool to .023 wire for example. I don't know what size wire you are using. Also there is an adjustment for the drive spool. Tighten the tensioner spring thumb screw to increase the feed tension.
    Apr 28, 2014 | Welding Tools
    Hello, I would like to purchase 3035 spool gun and attach it to my self made welder. Could somebody to tell me which power supply I have to provide for spool gun motor? DC voltage, amperage ? Can I use...
    the spool gun is a 12volt motor, i usely hook it to the power feed for the feed motor in the welder. it is also 12 volt . i have heard of some welders that have 110 volt feed motors but have not seen one yet but just to be save i would test the power feed to the feed motor before i made the connection.
    Mar 11, 2011 | Hobart Handler 210 Wire Feed MIG Welder
    I have a 50A spoolgun and wc-24 controll box, but i cain't adjust the heat, and it is way to hot, any ideas as to what the problem may be. it worked fine one day and the next day it was too hot and...
    The control box for the spool gun it's just an adapter to feed the right voltage to the wire feed motor, the heat (voltage) must be adjusted from the three knobs:
    1) Process Contactor knob must be dial on wire feeder CV using remote.
    2) Polarity Must be set on DC
    3) Voltage, depends on thickness of your work piece and wire gage, but 20 volts must be enough for up to 1/4" thickness and 035 4043 aluminum.
    I never heard of a 50A spool gun, probably you meant 30A.
    If your voltage it's erratic check the following:
    Clean and tighten connections both inside and outside unit.
    Check and secure lead connections to remote control.
    Be sure connection to work piece is clean and tight.
    Remove excessive coils from weld cables.
    If continues to be too high (hot) and can't control it, then you should send your machine to be checked that's probably a problem with the PC1 or PC2.
    If this was useful to you please vote. Thank you and good luck.
    Feb 13, 2011 | Miller Trailblazer 302 Welder Generator...
    When I press on the welding gun trigger the wire spool clicks but the wire won't feed. It's not the wire speed, spool doesn't seem to be stuck. No melted wire on tip. You can pull the wire through the gun...
    Feb 15, 2010 | Welding Tools
    Welding Tools Logo
    386 people viewed this question
    Top Welding Tools Experts
    Bill Boyd
    Are you a Welding Tool Expert? Answer questions, earn points and help others
