I have three window ACs in my entire mobile home(double wide). One at the back of the house, one in the middle and one in the front. Each one is plugged into its own outlet. If I try to run more than one AC at a time the breaker pops. They seem to all be on one breaker as well as several other items in the house(ceiling fans, alarm clocks, etc..). The breaker has a 30 on it and the AC's Im not sure what they use but the AC units say to use a 15 amp. What can I do to fix it and can I do it myself?
Susan
Comments:
Jul 10, 2009
- We have tried running just the one AC in the middle of the home but it does not keep the bedrooms on the both ends cool in this Arizona heat of 115. I won't use the extension cord.
Jul 11, 2009
- I somewhat thought the same of the middle AC. Well I do appreciate your suggestions, thewy were very helpful and until I can have a central air put in I will just try my best to cross cool. I am glad though for your comments because I was continually resetting the breaker and leaving the two end AC's on. It never popped at night, and to think we could of burnt up! Thanks so much.
Usually when I install a window A\C I prefer to run a dedicated circuit for the very reason that your encountering. Sometimes if you use a heavy duty extention cord you can find a circuit thats not used very much to plug into. Extention cords run in three catagories; light, medium and heavy duty. Mobile homes traditionally have lightweight wiring to begin with so use caution if you decide to try using an extention cord, only use maximum of 25 feet.
Susan; # A/C units in a mobile hme is a little much to much. I'm surprised it hasn't burned down. Upping yor circuit breaker would cause an extreme fire hazard.
Comments:
Jul 10, 2009
- Consider having an electrician assess your predicament and for your safety quit overtaxing the circuit you are on..And did you know that an a/c unit that runs on 220 volts is cheaper and more efficient that the three units you have combined? An electrician can run a 220 dedicated line and you can put a single A/C unit in one location, Get your windows back and realize the returns on the investment virtually on the first electric bill. And, not be concerned about losing all to a fire. Just thinking of you Susan. NO EXTENSION CORDS!!!
Jul 11, 2009
- Good Susan, no cords. Try cross cooling Turn one end on for awhile and then the other end. close all blinds or curtains. See if that helps. The middle a/c is self defeating. I wish I could do more.
gas was turned off to house for line repair. when gas was turned back on furnace would not light....
(More)
gas was turned off to house for line repair. when gas was turned back on furnace would not light. checked hsi without touching element. not cracked. shows resistance on meter. carrier 58RAV095-16.
How do i take my air conditioner off of override, it says to hold up/down to clear it but that...
(More)
How do i take my air conditioner off of override, it says to hold up/down to clear it but that obviously doesnt seem to be working.
Ge Zoneline heatpump works fine in the summer but in the winter with 45 to 50 degree days the...
(More)
Ge Zoneline heatpump works fine in the summer but in the winter with 45 to 50 degree days the compresser hardly runs. By turning the thremostate you can get it to run for a short period. I have 6 of these units and this one just started to act this way end of last winter. Do you think it could be the varistor or something else on the control board. Thank You
