Question about Garden
Why can't I find a serial number under the seat?
I need that to get a new bearing.
    Sergeant:
  • 287 Answers
Look for serial and model #s on the engine tag.
Posted on May 03, 2015
Can u tell me where the serial number for a 19.5hp craftsman motor is. The serial number on MOTOR. Not mower
There are a number of places it could be. Typically is it under the seat. Lift the seat up from the rear and check. Otherwise it may be located: 1. On plate of platform or rotor housing.
2. On front panel or under a frame of seat.
3. On blade housing inside the left door handle.
4. On plate lever control panel or gear.
Nov 05, 2017 | Craftsman Garden
11.5 Briggs Straton Poulan riding mower, location of MFG serial number
Depending on which your needing. The body model and serial decal is usually located either on seat or on the body under seat.
If it is the engine it depend if OHV or a L-head engine. OHV serial (date code) is on the valve cover. L-head is located somewhere on the engine's flywheel shroud.
Mar 11, 2015 | Poulan Garden
Where is the serial number - toilet is 25 yrs old and need a new toilet seat.
Typically there is no serial number associated with a toilet seat. The seat will either be a round front or an elongated seat. Just make sure the shape is the same when purchasing the replacement seat.
Jan 20, 2015 | Porcher Home
Steering huskee
Hello Rodney,
Do you have a model and serial number? (Usually located under the seat). I need this info to properly answer your question. I found a diagram that may help in the mean time.f1c8e24e-49b0-408f-8ad9-5ca7be758db1.gif
Oct 06, 2013 | Garden
Need to replace main bearing
It is seperate. Bearings can sometimes be real tough to remove especially without a puller. You may be able to get one from Auto Zone or O'Reilly's etc. Usually you pay a deposit for the loan of the tool and it is refunded when you return the tool. You can use a grinder but don't try to cut all the way through. Get close then hit it with a punch or cold chisel to snap it open. However you decide to remove it make sure to use penetrating oil. After it is removed it is very important to clean the area where the bearings sit. Penetrating oil on a rag will usually remove most stuff but often i'll bust out a piece of emery cloth or steel wool to get it as nice as possible. Also be careful sliding the new bearing into place. Put a little 3 IN 1 oil around the shaft where the bearing seats (don't use canned penetrating oil.) Do not tap on the outside of the bearing to seat it. Hopefully no real tapping will be needed, but some likely will. A punch against the inside ring of the bearing with light taps should be all that is needed. If you have to bang it on you didn't get the shaft clean enough and may have a devil of a time removing it without damaging it. They really should practically slide into place but it's got to be tight. You can do it though, it's not rocket science.
If i knew your model # i could probably be more help. The serial number is really only used for waranty purposes.
Jan 01, 2013 | Frigidaire Washing Machines
Need a belt diagram for a Huskee mower model # 4420294, where can I find one online?
That IS the number under the seat. I have the same problem, the data plate under the seat, it say's right there, "Model # 4420294. I called MTD and they even said that's not the right number. Can't find another anywhere, other than the Koheler number. I also have the id number and the serial number, but I doubt that will do me any good.
Apr 14, 2011 | Mtd Garden
Hello, People I have a Tunturi 202 rowing machine, and love-it. However, the little wheels under the seat have worn-through ... weep! Can anyone help me on locating replacement wheels for the...
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Mar 10, 2011 | Exercise & Fitness
Where can i find the serial number?
The manufacturer has a serial number
tool locator. Use this link and a flash player tool will run: http://www.pridemobility.com/resourcecenter/serialnumbers.asp
The serial numbers are usually under the rear cover of the scooter and that requires taking off the seat first. Hope this helps.
Dec 20, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Worn seat wheels on Tunturi 202 need replacing
Jul 01, 2009 | Tunturi Exercise & Fitness
R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Mar 31, 2009 | Exercise & Fitness
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
