Question about GE Profile JTP18 Electric Single Oven
We need a circuit pack number - GE Profile JTP18 Electric Single Oven
Is it still safe to use as the light is broken, I have tried 3 bulbs.
Hello Carol;
My name is Peter. I am retired field service appliance technician.
Your oven requires a special oven utility bulb. If you have used common house hold bulbs they can not handle the heat.
Lets assume you did use a special utility bulb. On the face of your oven when you open the door is a little plunger button (Switch). This is may be a dual activation switch if you have a self cleaning feature. So, you will have either one circuit for the light or two circuits, one for self cleaning and one for the light.
The circuit for the light is a separate circuit and is strictly for the light to turn on when you open the door and turn off when you close the door. You can operate your oven safely without the light working.
You may have a short, but I will bet on a bad oven door switch.
Go into the following website and put in your model number. You will get diagrams and component part numbers.
Your model number is located on a label either on the face of the oven when you open the oven door or on the side of the door. Water Filters Lawn Garden Appliance Parts
Mar 11, 2016 | Neff Ovens
My oven is about 10-15 years old and I cannot reset the clock after the power has been disconnected.
Hello. I need the model number to help you accurately and provide part numbers for your particular unit. Was the power turned off by you or was it a power outage(caused by lightning, construction, etc). If the power went out due to an outage, the main board might very well have been damaged. Power interruptions are notorious for blowing out or damaging circuit boards in ovens, microwaves, dishwashers, washers, dryers...the list is almost endless. Normally, the power going out doesn't do the damage--it's the restoring of the power(and the accompanying current surge) that is the culprit. If a board has been damaged by a current surge, if it wasn't knocked out completely immediately, 3-4 weeks after the event is the usual time when symptoms start appearing--caused by weakened electronic chips on the circuit boards starting to fail.
Sep 18, 2015 | Fisher and Paykel Ovens
Why won't door stay open?
Hello. Most often, any problems with the door opening or closing involves the hinge assemblies being damaged in some way. The part number for the pack of 2 hinges(right/left) is 8303989. I hope this helps you!
Jun 26, 2015 | KitchenAid Kitchen Aid KEBK101SWH Single...
I have a electrolux oven and the outer glass of my oven door has shattered. Do I need to replace just the glass or do I need to get a new door ? And where would be best to purchase it from ? The model...
Hayley, most times you can get a glass pack for oven doors. I tried to put your model number in at a couple of different websites and came up with zero results. Can you double check your model number and maybe try to take a picture of it and re-post or reply with that information and that could help us help you try to find a replacement.
Jan 28, 2015 | Electrolux Ovens
My electolux superba convection oven is not maintaining it's temperatures?
Heating elements cold be going bad look at them with a flashlight if either of the elements look thinner than the rest of it then it needs replacing before it goes out completely. With aloud bang a bright arc flash and smoke. Very scary. There's a metal tag on the inside of the oven door jam.write the model and serial number down. Shut off the circuit breaker for the stove should be a 50 amp double breaker. Remove 2 small 1/4 inch screws. Slide the element out straight to you. Remove the 2 wires with the same 1/4 inch nut driver keeping the wires separated .Do Not turn on the circuit breaker till the new elements are installed! !! Use the model and serial number to get your new elements first.
Sep 26, 2014 | Ovens
I need wiring diagram for relay circuit board kenmore drop in stove model # 911-4558818
hello. go to searspartsdirect.com
enter the model number and you will get an entire set of schematics to review for free. Joe
Oct 12, 2010 | Ovens
I'm getting fault code f2 reading, do I need to replace the oven temperature sensor or relay board? what part number is this and where is it.
Hi
Thanks for using FixYa. Error F2 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
GE Profile Wall Oven Circuit Board
http://www.searspartsdirect.com/partsdirect
I HAVE QUESTIONS. THIS THERE 240 VOLTS AC TO OVEN. YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH 3-5 TIMES FAST TO GET IT TO RESET. IF THE LAST THING YOU DID WAS A SELF CLEAN THEN YOU MAY HAVE A SAFETY THERMOSTAT PROBLEM. IF YOU CANNOT FIND THE WHOLE MODEL NUMBER ON THIS SITE CALL 1-800-GECARES THEY WILL HELP YOU WITH PARTS
Apr 25, 2010 | GE Profile JTP18 Electric Single Oven
Stoves model number 059040404
try the simple things first. check continuity thro the grill element - likely the element is open circuit
Aug 22, 2008 | Ovens
It shows a code F1
It means the worse. It is the watchdog circuit (tells what the ovens doing at the time) in the ERC (Electronic Range Control) which is the circuit board. It calls to replace both the circuit board and the touchpad. You're looking at about 100 -150 bucks. Sorry.
Jan 28, 2008 | Ovens
GE Profile JTP18 Electric Single Oven Logo
61 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
