Question about Xerox Workcentre 7335 All-in-one Laser Printer
How do I correct double shading on printing? - Xerox Workcentre 7335 All-in-one Laser Printer
How to solve printing was double shaded
If you have one of those deskjet printers with two heads: black and color, might be that heads us unaligned.
Look ar printe's utilities.
In tnis case your printer has an application to align the two heads avoiding this "double shaded" effect.
May 02, 2015 | Office Equipment & Supplies
I replaced my black and magneta ink cartridge today and documents will print out only nice shade of blue.
may i assume you removed tapes at the electronic side of cartridge?
shake the cartridges.
Now your computer should have a utility for settings the cartridge for
first time after loading them. Thisis to make sur the colors are mixing
to give the right shade.
Normally 1 single shade means the color cartridge is ending so may be you
double check you are not returning the same ending cartridge in the printer.
Hope that helped
Aug 03, 2011 | Brother MFC295CNAll-In-One InkJet Printer
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
For some reason I see slidly double shade double
replace the convergence kit- (2) stk-392-560 and picofuse 5 amp
Jan 14, 2010 | Sony KP-51WS510 51" Rear Projection...
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Printing with double lines and blurry on left side of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
Samsung SCX5312 copies look very pixilated/grainy. Prints look fine. I cleaned the Optics. This got rid of the background but did not correct the CQ. Has new drum & fuser. Problem is definitely in...
Hello sir;Did you reset copier after you replace a new drum? if not please do it, if still have problem, you need adjust shading;
Close doccument feeder, select adjust shading . press "set up" An image will be scanned and a ccd shading profile will be print put, if the printed image is different than the image the ccd is bad.
Aug 14, 2009 | Samsung Office Equipment & Supplies
Printing pdfs with highlighted text/shaded areas
That just means that you don't have a postscript enabled printer, or possibly you're using a black and white only printer. You might be able to print highlighted items normally on other printers, but will have to remove the highlighting to see the text on the one that you have. Alternatively, if removing the highlights isn't possible, you might try selecting all the text and then pasting that into a new document in a word processor or another similar program. If you do have a color printer, and need to print what you're seeing, you can arrange the document so that it is centered on your screen and then press: "Alt + Print Screen" at the same time. You can then open MS Paint or a similar photo editing program and paste ("Ctrl + V") the screen capture into the program.
Let us know if you need further help.
Hope this will FixYa!!!
Oct 30, 2008 | Adobe Acrobat 7.0 for PC
Xerox Workcentre 7335 All-in-one Laser Printer Logo
53 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
