Question about Miscellaneous
The tuning indicator and light is not working. Can I fix this myself? Is there schematics I can find? It's for a Soundesign model 5959. Thanks.
    Master:
  • 269 Answers
I have a hobart and nonthing will work not even the lights on front, i have checked the 2 fuses on front and they good, got any orther ideas
I would need more info to trouble shoot this fryer problem myself, but you could call Hobart directly, and ask for warranty/service dept... They can walk you through several things to help you figure out what's wrong with it...I know Hobart has a parts company here in Cincinnati, but their main factory is in Hobart, Ohio... Thanks, Susan 888-542-5959 www.restaurantequipmentinc.com
Restaurant Equipment Outlet, Cincinnati, OH 45223
Aug 23, 2011 | Hobart Kitchen Appliances - Others
I need to find an owner's manual for Soundesign Jukebox Alarm Clock model 3160J
You can get all kind of Soundesign Jukebox Alarm Clock manualshere: http://manuals-market.com/search.php?cmarque=PERFORMANCE%20TEKNIQUE&modele=ICBM%20779. After clicking this link you will be forwarded to a page contains aform. You need to fill up that form. Most of them are pre-filled. You need towrite "Soundesign" in Brand box and model number in "model number" box. Please don't forget to mention "Jukebox Alarm Clock" in the"description box". Finally accept their "terms and condition" and click on"search" tab. Hope this will help you. Good Luck.
Aug 20, 2011 | Audio Players & Recorders
Fryer pilot will light and heat up then when burners kick off and try to relight the pilot is out
Could be thermostat is bad and/or high limit as well. I'd start with the thermostat, and if that doesn't fix it, move onto the high limit...I could get you a price, but I need a model/serial number both first...
Please call 888-542-5959 with any other questions, or email us at reocincinnati@Yahoo.com.
Our website is www.restaurantequipmentinc.com Thanks, Susan
Aug 08, 2011 | Star Kitchen Appliances - Others
1997 Vauxhall Passat 1.6L Saloon (P-Reg). Following Flat battery, Right hand side indicators are permanently on - Noticed it as soon as I connected battery charger as ignition key had not even been put...
got me thinking here .,,,,in all honesty havent come across this on this model before but i have had it on a renault i think it was and it was caused by a chaffed wire under the bonnet near the power distribution box cant see it being the computer as this would run a feed to the relay not direct to the lights as the ECU is only chips and not many power passing transistors in a car ECU ,no check the wiring loom ,also dodnt these vehicles have a parking light that comes on either side of the car when indicator is put to that side ,could something be wrong with that maybe ,Must say though never heard of a vauxhall passat though ,Were you on night shift when you wrote this
Jan 13, 2011 | 2004 Volkswagen Passat
I picked up a new Maytag model MERH752BAQ today. The element indicator lights or not working on the control panel. Is there something I can do myself, or will I have to contact the dealer? Thanks
i would guess you have a warranty,so i would not mess with it..either the control board is bad or the indicator is defective, or a bad sensor
Dec 19, 2010 | Maytag Kitchen Ranges
Serivce engine soon , light is on. how do i fix it myself thanks
give it an oil change and spark plugs or it might need an entire tune up
Apr 28, 2010 | 2007 Toyota Corolla
My roland discover 5 wont tune - not to default 440Hz or any others - wont stabilize - and the bottom corner of touchscreen where it says"440 -Do it" for resseting to default concert pitch dowant work/...
The unit may have the problem that befalls the Palm Pilots where something gets under the escutcheon and presses on the touch screen at the edge which overrides any other inputs.
Another possibility is a stuck button. The buttons are usually scanned as a matrix and at startup if a button is stuck that can make unit unresponsive.
Without a logic analyzer and the firmware listing you likely would not get far if one of the logic chips has gone bad unless it can be found using freeze mist and heat gun..
Stuck buttons or touch screen is usually easily found without schematic.
Apr 27, 2010 | Roland Music
My GE Washer model # WDSR2080DAWW is overfilling unless I take the hose off the side that controls the load indicator switch and blow air into, once I do that, it will stop filling and work perfectly, how...
I fixed my washer by taking off the hose that controls the load indicator switch and blew air into it and it works like a charm, so please don't charge me 20 dollars cause i fixed it myself, thanks
May 13, 2009 | GE WBSE2090A Top Load Washer
Miscellaneous Logo
62 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
