Question about Dryers
Replaced the belt. Why does it keep coming off the tensioner now?
Can I find photos/manual somewhere to see what is wrong? Dryer is a Hotpoint Ultima TCUD97B
  • Dryers Master
  • 5,323 Answers
Did u connect the spring properly on tensioner
Posted on May 04, 2015
Testimonial: "I'm not sure, I was looking for instructions or technical diagrams but cannot find anything"
  • Jorge Rendon
    Jorge Rendon May 05, 2015
    does it look like this
My hotpoint lumina super silent is starting a cycle but only loads the water and then doesn't spin it just stays still and counts down the time until theoad finishes and then empties the water. What's...
it's not named after that other car, is it? It's a hotpoint ultima super silent. Most likely suspect is the drive belt for the tub. Remove back cover and find the tech sheet stuffed in the unit for lots of secrets, shortcuts, and commonly replaced parts with the correct mfr part numbers. Check to see if the belt has come loose and why.
Mar 05, 2015 | Hotpoint Washing Machines
Hotpoint washing machine. Replaced drive belt yesterday but fell off again during cycle. Also tightened up pulley. What have I not done?
You most likely didn't tighten up the belt tensioner, this adjusts the tightness of the belt, so as it stretches, during use, this can be, adjusted out.
Apr 07, 2010 | Hotpoint Ultima WF860 Front Load Washer
F05 keeps coming up on my ultima 860 hotpoint 1600 spin w/m,we cant find manual,what is problem?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Fo5 is a pressure switch fault; areas to check are pressure chamber for blockage, pressure pipe sump and pump. Click on a link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
Keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima washer dryer
ok lay the machine on its side the side with the soap draw under you will find the outlet pipe runing to the pump then another hose going from the pump to the bottom of the drum. if you disconnect the hose from the bottom of the drum you will find the filter remove this hose from the other end and clean the filter and hose with hot water once replaced check the hose in tight it may be tricky to replace stand up the machine and test using water only and an empty drum.
Nov 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WDM73
The whole tub has to come out then split,it is worth changing bearings at same time.Parts can be supplied by us.
Oct 10, 2008 | Hotpoint Ultima WD72 Front Load...
How to change dryer belt on Asko 7305 dryer
You have to pull the back off the dryer.Then you,ll be able to see how it comes off.Ussally its on two pulleys similar to a car.There may be a tensioner on it to to keep it from slipping.If there is one you,ll have to losen it to remove the belt & replace it,then tighten the tensioner back up.Ussally you keep about a 1/4" to 1/2" free play on the belt.You use a sraight edge on the two pulleys to measure it with the belt on,tighten belt tensioner till you have the recommended tighteness.
Nov 05, 2007 | Hotpoint NBXR463EBWW Electric Dryer
How do I replace the belt that makes the drum spin on a Hotpoint Ultima WF860 ?
The belt goes around the drum and onto the motor pulley. No need to loosen anything. Put tension on the belt and fit it onto the motor pulley by gently turning the motor and pushing the belt onto the pulley at the same time.
Oct 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
isolate from mains. undo door gasket and check interlock id ok. interlock is mounted on cabinet on rhs
Mar 11, 2007 | Hotpoint Ultima WD72 Front Load...
Dryers Logo
66 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
