How do I know whether the blades are properly aligned?
  • 932 Answers
Martin,
The manufacturer puts spacers between all of the blades to keep them at the proper alignment. If you are having issues with paper balling up in one area, it may be that one of those spacers has failed. I am not sure if you can get spare spacers or not.
Posted on May 15, 2015
What is the procedure of putting a new blade in a shopsmith scroll saw?
for more info please see the owners manual here: http://www.shopsmith.com/ownersite/manuals/845539.pdf and view page 31 -32
  1. Slide the new blade into position, working it up through the table slot, around the guard, and onto the wheels, as seen in Fig. B-26. The teeth must be pointing down and toward the front of the Bandsaw (and toward you). Position the blade approximately in the center of the rubber tires and in between the guide blocks.
  2. Check the tension scale alignment. With the blade slack on the wheels, the red indicator bar should be parallel to the left edge of the tension scale. If this is not the case, follow the alignment procedure described in Alignment section. Fig. B-26 Fig. B-27
  3. Tension the blade, turning the blade tensioning screw clockwise, as demonstrated in Fig. B-27. Notice that as you turn this screw, the red indicator bar moves, because it is actually the flat spring that tensions the blade. The blade tension is properly set when the edge of the bar disappears behind the scale at the marking for the blade width you're using. On a few operations, such as sawing thick stock with a thin blade, it may be necessary to increase the blade tension slightly beyond the normal setting. However, this increased tension will shorten the life of your blade. Always remember to reset the tension screw when you no longer need extra tension
  4. After you've spun the blade several times by hand, it should be centered on the three roller bearings, indicated in Figs. B-29 and B-30. The back of the blade should rest against the auto-track roller bearing and the lower blade guide roller bearing, and it should be no more than 1/64" away from the upper blade guide roller bearing. If the blade is not properly positioned on the bearings, follow the procedure described in "Adjusting Roller Bearings" in the Alignment section.
Jan 18, 2016 | Blade Saws
Bought the new ryobi 7 1/4 inch miter saw. Factory installed blade stops but spindle doesn't. There is an inner ******/washer, then the blade, then an outer ****** and then the bolt. Why is blade stil
The shoulders on the washers have to be properly aligned with the hole in the saw blade so the nut can tighten properly. Are the washers turned the right way? Try flipping one or both the opposite direction.
Sep 13, 2014 | Saws
Blade on my 9 inch mastercraft band saw does not tension properly
Check if the tires are align. The blade must be on the center of the tires. Check for both tires for wear . You may want to
check the blade guides too. They must not touch the blade. I just purchased new tires on www.bandsawparts.com for a
friend. We've learned that his tires are well worn out that's why the blade keeps on coming off on the wheels.
Mar 07, 2013 | Saws
How do I put the blades back in my model 059750 005 000 trimmer
I have the same model. Actually, they're quite old. If you don't have replacement blades already, you can find them at Sally Beauty Supply ( sallybeauty.com for a location near you ) for about $20 for this model. The replacement blade may not be available online, but my local store has it available for purchase. You may find it available at your local beauty supply.
Remove the two screws that hold the 2-piece blades in place. Remove the blades and take note of how they are situated together. Both have flat sides that slide together where the teeth meet. Your replacement blades should be arranged in the same manner when you put them back on the trimmer. First place the smaller blade onto the clip. This is best done by aligning one of the diamond shaped hole with one of the flat prongs, then pushing the balde towards the side to help snap the other prong into the other diamond shaped hole. Once this is securely in place put the larger blade on so that the smooth surfaces touch each other and the holes for the screws are lined up. Replace the screws securely but do not tighten it. Do the same with the second screw. You should just barely be able to slide the larger blade around with some effort. You will need to do this to properly align the blades together. The teeth of both blades should never meet at the tip. The smaller blade should be about 1/16 - 1/8 of an inch away from the tip of the larger blade and should be evenly spaced all the way across the width of the blade. If you have this set properly, go ahead and tighten one of the screws. Check the spacing of the blades again to ensure they have not moved. If they have, you just need to slightly loosen the one tight screw and re-adjust. Tighten the screw back down. If all is aligned propperly, you should be able to tighten the second screw without any problems. Don't forget to lubricate the blades with the proper oil. Check you local beauty supply store if you need oil. That's it. They are now ready to trim.
Dec 06, 2010 | Health & Beauty
1/8'' blade keeps jumping off wheels on Ryobi BS 900...!! Checked wheels for alignment and both are square to each other. TRension seems right, although I can't find manual to confirm proper tension....
I found a manual online, however it did not give specifics on blade tension. I do know that the blade has to be pretty tight and that it the blade should be just touching the bearings on the back. I hope this is enough help, if not let me know and I'll see what else I can do.
Jan 09, 2010 | Ryobi 9 in. Benchtop Band Saw
Dont know how to install blade
on blade you will notice two small phillips head screws. remove both screws with thumb on blade. with other hand remove the blade. Blade has two parts. The smaller blade lays on top of the larger blade. align two blades together. Hold the blade compartment in your hand upward with smaller blade on top of the larger blade. On the clipper in between the two hole where screws go there is a small arm with a round shaped tip. Put the base on to the blades a fixing the round shaped arm into the blades ensure proper fitting. With hand holding the clipper turn over while thumb is holding the blades in place and replace screws.
Oct 07, 2009 | Andis 01690 Hair Trimmer
Motor on / Blades don't move.
Sounds like the internal gears or drive shafts are either broken, or out of alignment. Not exactly something that can be easily fixed usually. Hopefully, it's still under warranty?
Mar 13, 2009 | Fellowes OD700C Shredder
Reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Sep 03, 2008 | Wahl 9765-301
T-Outliner has stop cutting!
good advice but the best way to align is to know the exact aliment,pay attention to how the blades are set in relation to one another when they cut correctly,and remember this so that next time wont take so long to adjust the blades.
Mar 12, 2008 | Andis 01690 Hair Trimmer
256 people viewed this question
jasbo
jasbo
