Question about Biasi B-6 Oil Boiler w/ Riello Burner - 153,000 BTU
What does the white smoke coming out of the top of the flu on my oil boiler mean
    Welcome Back:
    Visited the website for 2 consecutive days.
White smoke can mean boiler is running too lean, general rule of thumb is, too much air and not enough fuel gives smoke, too much fuel and not enough air gives black smoke. Possibly blocked filter or bad pump.
Posted on May 02, 2015
  • 17,173 Answers
White smoke means steam and that would be caused by a leak in the heat exchanger coil of water in the fuel.
HI i have karzima r which is 5 years old. but from past one month it start throwing white smoke from exhaust. this is only in the morning & evening start up. and white smoke only come out when i r
white smoke= lean fuel, dark smoke= rich fuel. white smoke also could mean mean a blown head gasket allowing water to mix with the oil (very bad). Run it for a bit then take out and look at the oil filler pug. if the oil is frothy or bubbly and has the color of hot chocolate there is water in it. Replace head gasket and flush all systems immediately! Pary for the best
Mar 27, 2014 | Hero Honda Motorcycles
When drivnid with oil in my car white smoke comes from my exhaust, when the smoke stop the oil light flashes on the dash
Usually white smoke means the engine is burning oil and-or coolant thru the cylinders.
Could be a blown head gasket or other engine damage.
Dec 04, 2012 | Cars & Trucks
What does white smoke coming from exhaust of a 01 'suzuki gsxr 1000 mean when starting only?
For motorcycles with 4-stroke engines: The white smoke from the exhaust means that the engine oil is leaking into the combustion chamber where the petrol burns. ... This eventually means that you have to get your piston changed along with the piston rings that prevent the engine oil leaking into the combustion chamber.
Mar 14, 2017 | NiceCycle Cell Phones
White smoke comming from the left side of the egine
If your smoke is coming out of the tailpipe......White smoke usually means that water or antifreeze is being burned by your engine, blue smoke is oil and black smoke is fuel ( too much fuel) . If it is coming from under the hood you need to figure out where it is coming from.
Jan 01, 2018 | 2002 Hyundai XG350
I HAVE A 1995 KAWASAKI KLF300C 4X4 AND IT STARTED TO MAKE A NOISE FROM MOTOR AND WHITE SMOKE COMING OUT MUFFLER AND YOU HAVE TO GIVE IT A LITTLE MORE GAS TO MOVE
White smoke means head gasket is leaking coolant in to combustion chamber. Look at the engine oil for signs of coolant in the oil and oil floating on the top of coolant. You could also do a compression on the motor
Dec 20, 2010 | kawasaki KLX 300 R Motorcycles
White smoke coming out talipipe
cracked head or blown head gasket
Nov 07, 2010 | 1985 Chevrolet Chevy
I have a Laars Max Boiler 75, 90K with white smoke out chimney
Hello
Yes,more then likely its moisture from the high effenicey system of the boiler.
I have a laars boiler at work and some mornings when its cold out it looks like there is a fire, which is really only steam.
As long as your not shutting down on low water failure or loosing pressure and holding temp.This is normal.
Hope this helps.
Jan 26, 2010 | Heating & Cooling
My 93 maxima got no power an smoke started to come out the tail end.
The best test is a compression test.
Blue smoke means it's burning oil, due to worn out piston rings.
White smoke means it's mixing antifreeze and oil due to a bad head gasket or cracked head or block.
Nov 12, 2009 | 1993 Nissan Maxima
I have a 3000GT VR4 from 1997. A month ago I had almost no oil in the car, way before due oil change. Yesterday, white smoke was coming out of the exhaust. One mechanic told me last week that I need a...
Hi Maria,
Does the white smoke occur at start up then go away?
Was it cooler out the night before the white smoke started?
Likely it's condensation burning off.
To be on the safe side have a compression test run on all cylinders. It's a quick, easy and cheap way to find out if the head gasket is ok.
Also, I strongly advise you to get some second or third opinions for the remaining symptoms. Something smells fishy. I'm sure you know what I mean.
If you comment back or repost, I will do my best to help you out.
Best regards
Mike
Sep 25, 2009 | 1997 Mitsubishi 3000GT
Trying to diagnose an internal engine smoke problem, 06 prius was working fine, all of a asudden i hear the gas engine come on and it sounds like valve or rocker noise, very lightly, i go to check the oil...
White smoke coming out of the oil fill cap is not good, it means there's water in there (white smoke = water, blue smoke = oil, black smoke = lots of junk in gas or ruined engine). I suspect bad head gasket or cracked block.
Jun 14, 2009 | 2006 Toyota Prius
Biasi B-6 Oil Boiler w/ Riello Burner - 153,000 BTU Logo
474 people viewed this question
Top Biasi Heating & Cooling Experts
richie46
 Gramps
Gramps
Level 1 Expert
Are you a Biasi Heating and Cooling Expert? Answer questions, earn points and help others
