Question about LG Cell Phones
Can u help me get this straitened out I am disable and it is relay upsetting me been at this for almost an hour
  • LG Master
  • 5,631 Answers
I understand you made some question but if it was not answered for an hour, my best advice it that you should ask it again and hope someone might have the best answer..
Posted on May 02, 2015
How do I reset the computer on my subaru forester 2004
Hi to reset computer just unhook the battery leads for an hour or so, Also check your fuses again, this time with a tester. Sometimes the break in the fuse wire is so small you miss it. Also you may have a loose connection(fuse not pushes all the way in). Check your relay switches in the black box in the engine bay as well as the fuses in the same box. Hope this helps.
Oct 20, 2017 | Subaru Forester Cars & Trucks
2003 Hyundai Sante fe A/C fan and rad fan not turning Fast enough while A/C is on but work OK when engine come to temp. ac starts off cold then gets warm after about 5 miles.
make sure radiator and or condensor fins are not restricted with dirt , bugs etc. poor airflow across the condensor. high side pressure could rise too high causing compressor to cycle off and on and not cool the freon properly.not sure what you mean when you say you play with the relay and it comes on. compressor or the fan? pull the relay and look at the female pins and make sure they are not spread open too wide. is the check engine lamp on? sometimes computers will disable ac for some other faults. im not sure if you mean the compressor is turning off and staying off, or just not cooling well due to fan problem. if its turning off it could be a control head problem or the pcm disabling it for another reason. or if you are manipulating the relay then compressor kicks on you may have a bad relay. hope this helps
Jul 14, 2012 | 2003 Hyundai Santa Fe
Small auto with skid marks light is on and check adv trac light light comes on and stays on. This began after the rack and pinion was changed. May be related my not. The steering wheel is also tilted a...
So the steering rack somehow has the steering
column out of position. That shouldn't happen
That has to be resolved
The Dash Lights are ABS Brake System Related
Another problem put in your truck
All I can say, I'am thankful I have always done
my own work. Now you know why
I would chaulk that up to whatever
You should go back, but why would you,
only to get upset
Shell out more money at a different
shop to get it repaired correctly.
You do know that you had to have it
aligned after the rack went in
No alignment rack,run.
Sorry,your not alone
Apr 27, 2011 | 2005 Mercury Mountaineer
I can't get washer to start. I believe the top
Washing machines have a safety switch on the lid. If the lid isn't shut, if won't run. You may have upset the safety switch. Depending on the machine, it should either have a micro switch that is tripped by the lid or the lid will have a tab that hits a switch as the lid closes... be sure to listen for a positive click ... you may try bending the hinge a bit to make proper contact too.
May 26, 2010 | Washing Machines
Peugeot 206 diesel starting problem! help!!!
the starting problem has nothing to do with a new exhaust system being fitted,, it could be the car alarm cutting off the fule pump though,,, try reseting the alarm it may have been upset by the work done on the exhaust,,,
Feb 19, 2010 | 1991 Peugeot 405
Can not log into my face book account
Please need help..i cannot sign in into my fb account
Oct 05, 2009 | Facebook Social Network
My friend Mel is in urgent need of either some new indicators or a relay switch for her imported Toyota Lucida. She is disabled and really needs her car to get around. I'm currently online for roughly...
Hi
The relay flasher for the indicators for 1990-2000 tarago/previas is behind the drivers dash board, i know this first hand because i sell tarago parts and pull them out all the time.
cheers
Jan 14, 2009 | 1997 Toyota Previa
Cell Phones Logo
29 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
