Question about Garden
How do I re4place the belt on my s-wft-16022 4 cycle field trimmer? I have the manual - but I need a video
Southland Brush/weed trimmer
    Top Expert:
  • Garden Master
  • 52,126 Answers
Seems like you need to remove the front assembly put belt on and replace front assembly .
Posted on May 02, 2015
How to change drive belt on craftsman weed eater on wheels
Hello, this is the best way to do this. Go straight to you tube....in the search area type in those key words, a video will help you 10x better than writing it down. Visualization is key
Sep 26, 2015 | Craftsman Garden
Worx electric grass trimmer / edger wg116 restring. Need this one not 117.
Demonstrated on a Worx String Trimmer - YouTube
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
Sep 18, 2015 | Worx Garden
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the gas to oil ratio for weed eaters?
Most gas weed eaters use 2-cycle engines. For the Homelite 2-cycle engine trimmers, use a 50:1 ratio of gasoline to the Homelite lubricant. (For 1 gallon of gas, add 2.6 oz of the oil.)
Many Homelite tool manuals are available here: http://www.homelite.com/service_support/product_owners_manuals . Scroll down to find your string trimmer.
I hope this helps.
Jul 16, 2011 | Homelite Garden
Manual
Typically 32:1 to 40:1 for all these models. Use 35:1 and modern 2 cycle oil and you will be fine. :)
Apr 29, 2010 | Poulan 17" T&E Gas Trimmer
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Need motor brush
Try a power tool repair shop
Try an electric motor repair shop
Try to find brushes that have the same length spring, same size spring. If they are a little big, they can be made smaller by dragging them on a flat file 'till they fit nicely.
Apr 28, 2009 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Weed eater does not start
I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Craftsman manual for a 4 cycle lawn trimmer
I have a craftsman incredi-pull 4 cycle, I changed 4 cycle oil, too much smoke coming from the machine, what I can do?
Nov 11, 2007 | Video Game Consoles & Games
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
