Question about McLane 3.5 HP Gas Edger & Trimmer 801-3.5RP-CA
What type of oil do I need to put into my edger? Regular Sae 30 oil or synthetic oil?
  • 991 Answers
Synthetic is best for longer oil change intervals but you require an oil filter to reach those service intervals. You are better of using normal mineral based oil and changing it more often.
Posted on May 02, 2015
  • 1 more comment
  • Anonymous May 08, 2016
    Wrong answer here....one we need to know is weight and type anybody manual?
  • Glick
    Glick May 08, 2016
    have a manual?
  • terry stevens May 08, 2016
    5w-30 or 10w-30
  • 4 Answers
It does not need synthetic oil
  • 3,961 Answers
It does not need synthetic oil.
What type of oil does it use?
I think all of these 4-stroke trimmers use SAE 30HD oil. I recommend synthetic. If you use synthetic, you can get away with using a multi-viscosity like 10W-30 if you can't find straight SAE30 synthetic, but don't use muti-viscosity conventional oil in these machines.
Sep 10, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What kind of oil does my yard machine take? 22" 123cc
Use regular SAE 30 HD automotive oil. I recommend synthetic. If you choose to run synthetic, you can use a multi-viscosity oil like 10W-30.
Sep 02, 2011 | Mtd 22" Yard Machine Push Mower
Hello: I own a poulan,500 series pushmower. The
Always use HD in any engine, especially small ones. Most regular SAE 30 is HD anyway, but nowadays, some is not with recycling and all. May I recommend synthetic? It will clean the engine, lubricate better, allow the engine to run cooler and possibly guarantee no mechanical breakdowns of the engine due to it's superior lubricating quality. Advance Auto Parts has their house brand oil now available in synthetic. . IF using synthetic you can use a muti-viscosity oil, like SAE10-30, but NOT when using conventional oil. If you are steadfast on using conventional oil, always use HD and use SAE30, not multi-viscosity oil.
Jun 19, 2011 | Poulan "" Push Mower
What engine oil do I need for my yardman 6.0 HP push mower?
SAE 30 only; if using conventional oil. I recommend using synthetic engine oil. If you go with synthetic, you can use a multi-viscosity oil like 10W-30, but only use staight SAE 30 if using conventional oil. Many benefits to using synthetic oil. It cleans the engine as it runs, it provides superior protection and helps cool the engine parts better, and it almost assures you 100% that your engine won't fail because of the type of oil used.
Jun 18, 2011 | kawasaki Garden
Where can I get the type of oil needed for the yard machine(22 in) push mower?
You can use regular SAE 30 weight oil from the auto parts store. If you use multi-viscosity, make sure it is synthetic, otherwise use straight SAE30 oil.
May 27, 2011 | Mtd 22" Yard Machine Push Mower
Type of oil needed
Briggs recommends you use as SAE 30 weight oil if using conventional oil. Multi-viscocity oil (like 10W-30) is acceptable if using synthetic oil, that is 100% synthetic, not a blend.
Apr 05, 2011 | Briggs & Stratton Garden
Which oil should be used for mastercraft 60-3975-8 snowblower
A good rule of thumb is: In 2 stroke engines, use synthetic or synthetic-blend 2 stroke oil
In 4 strokes, if it is cold, using regular SAE oil...SAE 30 only...if using synthetic oil (highly recommended), then you can get away with using a multi-viscosity oil like 10-30. Synthetic 30 weight is OK too. Just in cold temps, standard multi-viscosity oil does not perform well and manufacturers like Briggs caution against using it, stating engine damage can result.
Dec 11, 2010 | Garden
What Kind Of Oil Do I Put In My 91 Toyota Pickup. 10W-30 or 10W-40?
Depends on the season and temperature that it will be driven in.
Generally 10w-40 is for the summer, and the thinner 10w-30 is for the winter, if you so desire.
According to the chart, 5w-30 is preferred but 10w-30 can be used in 0 deg. F up to 100 deg. F and beyond.
Fuel and Engine Oil Recommendations GENERAL INFORMATION Oils The SAE (Society of Automotive Engineers) grade number indicates the viscosity of the engine oil; its resistance to flow at a given temperature. The lower the SAE grade number, the lighter the oil. For example, the mono-grade oils begin with SAE 5 weight, which is a thin, light oil, and continue in viscosity up to SAE 80 or 90 weight, which are heavy gear lubricants. These oils are also known as "straight weight'', meaning they are of a single viscosity, and do not vary with engine temperature. Fig. 1: Look for the API oil identification label when choosing your engine oil tccs1235.gif
Fig. 2: Before installing a new oil filter, coat the rubber gasket with clean oil tccs1901.jpg
Multi-viscosity oils offer the important advantage of being adaptable to temperature extremes. These oils have designations such as 10W-40, 20W-50, etc. The "10W-40'' means that in winter (the "W'' in the designation) the oil acts like a thin 10 weight oil, allowing the engine to spin easily when cold and offering rapid lubrication. Once the engine has warmed up, however, the oil acts like a straight 40 weight, maintaining good lubrication and protection for the engine's internal components. A 20W-50 oil would therefore be slightly heavier than and not as ideal in cold weather as the 10W-40, but would offer better protection at higher rpm and temperatures because when warm it acts like a 50 weight oil. Whichever oil viscosity you choose when changing the oil, make sure you are anticipating the temperatures your engine will be operating in until the oil is changed again. Refer to the oil viscosity chart for oil recommendations according to temperature. The API (American Petroleum Institute) designation indicates the classification of engine oil used under certain given operating conditions. Only oils designated for use "Service SG'' or greater should be used. Oils of the SG type perform a variety of functions inside the engine in addition to the basic function as a lubricant. Through a balanced system of metallic detergents and polymeric dispersants, the oil prevents the formation of high and low temperature deposits and also keeps sludge and particles of dirt in suspension. Acids, particularly sulfuric acid, as well as other by-products of combustion, are neutralized. Both the SAE grade number and the API designation bottle be found on the oil can. For recommended oil viscosities, refer to the chart. Fig. 3: Viscosity chart 86821236.gif
SYNTHETIC OIL There are many excellent synthetic oils currently available that can provide better gas mileage, longer service life, and in some cases better engine protection. These benefits do not come without a few hitches, however; the main one being the price of synthetic oils, which is three or four times the price per quart of conventional oil. Synthetic oil is not for every truck and every type of driving, so you should consider your engine's condition and your type of driving. Also, check your truck's warranty conditions regarding the use of synthetic oils. Both brand new engines and older, high mileage engines are often the wrong candidates for synthetic oil. A synthetic oil can be so slippery that they can prevent the proper break-in of new engines; most manufacturers recommend that you wait until the engine is properly broken in 3000 miles (4830 km) before using synthetic oil. Older engines with wear have a different problem with synthetics: they leak more oil as they age. Slippery synthetic oils get past worn parts easily. If your truck is leaking oil past old seals you'll most probably have a much greater leak problem with synthetics. Consider your type of driving. If most of your accumulated mileage is high speed, highway type driving, the more expensive synthetic oils may be a benefit. Extended highway driving gives the engine a chance to warm up, accumulating less acids in the oil and putting less stress on the engine over the long run. Trucks with synthetic oils may show increased fuel economy in highway driving, due to less internal friction. If synthetic oil is used, it should still be replaced at regular intervals as stated in the maintenance schedule. While the oil itself will last much longer than regular oil, pollutants such as soot, water and unburned fuel still accumulate within the oil. These are the damaging elements within a motor and must be drained regularly to prevent damage. Trucks used under harder circumstances, such as stop-and-go, city type driving, short trips, or extended idling, should be serviced more frequently. For the engines in these trucks, the much greater cost of synthetic or fuel-efficient oils may not be worth the investment. Internal wear increases much quicker on these trucks, causing greater oil consumption and leakage.
Nov 06, 2010 | 1991 Toyota Pickup
McLane 3.5 HP Gas Edger & Trimmer 801-3.5RP-CA Logo
238 people viewed this question
Top McLane Garden Experts
Lawrence Oravetz
Vernon Taylor
terry stevens
Are you a McLane Garden Expert? Answer questions, earn points and help others
