Question about Whirlpool Washing Machines
How do I remove the lid from a top-load wash machine in order to repair the lid switch?
Whirlpool model # SM 8525492-A
    Top Expert:
  • 2,899 Answers
Most have snaps holding the top down. Just, carefully, pry upward at the front of the lid edge.
Posted on May 02, 2015
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
How do I take the top off a Whirlpool washing machine to repair/replace the lid switch?
The link is a great general disassembly video that includes several top loader design,
Whirlpool Washing Machine Repair
Depending on your specific model it can be simply removing two screws on the top and then removing the two spring clips and the lid plug.
Hope this helps?
Aug 25, 2016 | Whirlpool Washing Machines
Lost clothes in Whirlpool top load SM 8525492
There is NO way that any clothing fell over the top of the tub into the sides of the washer, Emily. NO way. It's nearly impossible to believe that you even had enough clothing in there to spill water.
If you stuffed it enough to force clothing over the top of the tub, then the agitator could not possibly have functioned.
Just for the... impossibility... that clothing DID spill over the top, to get them out you would have to pull the dryer out and remove the back and/or the top. You'd see the spilled clothing immediately.
No - no, no, no. I CANNOT believe you overloaded it that much.
Aug 04, 2014 | Whirlpool Washing Machines
How do I increase the water level on my Whirlpool Ultimate Care II SM 8525079 Top Load Washer
You have a faulty water level switch. Replace the switch to get the correct water levels. Here is the switch to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Replace lid switch assembly kaws850
The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
On the particular model you have listed, the lid switch should be located under the console near the right rear lid hinge.
You will need to use the steps in the link provided to remove the exterior case to access the switch to see how the actuator and lid hinge interface. You washer is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
This is a very simple repair, but if you have any questions along the way, please let me know. I hope this is helpful to you.
NOTE: If you have not pruchased a new lid switch yet, the part number is 8054980. It can be purchased at appliancepartspros.com for about $18.
Oct 30, 2009 | KitchenAid KAWS850L Top Load Washer
My washing machine is filling up with water but not going through the rinse cycle.
Check your lid switch.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all of them for the best price.
This is a very simple repair, that usually costs about $25 to $35 to repair yourself. If you have questions, please let me know. I hope this helps you.
Sep 14, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Not spinning
This is a common symptom of a lid switch gone bad. I know you stated that you jiggled the contacts, but the switch still may be defective. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: Some washer models have the lid switch located near either the left or right hinge of the lid. This type of switch is activated by a rod on the hinge pin. If not functioning, it can often be adjusted by bending the hinge rod until it engages the switch.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care II lsq8500JQ1 top...Problem
Ok folks to change the lid switch on these and many top loading Whirlpool, Maytag, Kenmore, etc is quite easy.
Steps to replace the lid switch:
1. Remove unit from AC.
2. Remove the loading door from the unit, or using some duct tape tape it closed.
3. Using a small flat bladed screwdriver find the 2 release catches on the front of the unit between the top cover and front panel. These are just snap claps to hold the top cover down. To release the top you will need to compress the latch using the screwdriver. Start with one side, then the other. Once you have released both clips the lid will lift up just like the hood of your car.
4. You will now be able to remove the lid switch from the unit.
5. Install the new switch and close the hood of the unit.
6. Test the repair by running the unit though a complete cycle.
A great place to order the replacement part for the unit is:
www.appliancepartspros.com
They ship same day on orders placed before 3pm EST. Overnight shipping is available, however I usually opt for the 2-3 day ground shipping and save the money.
If this switch replacement does not take care of the problem, you might need to replace the control board located under the front panel. This replacement is also very easy and takes about 10 min from start to finish.
Hope this helps everyone. Cheers,
Keith
Oct 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
95 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
