Question about Makayama Media Easy WiFi Radar
What version of Easy WiFi radar is compatible with windows 7 OS?
  • 3,961 Answers
The one they have now is compatible, 1.0.5. It does not run on Win 8.
http://en.softonic.com/s/easy-wifi-radar-1.0.5-windows-7
Posted on Jan 04, 2016
    Top Expert:
  • Makayama Media Master
  • 10,875 Answers
Read the manufactures notes
Posted on May 02, 2015
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
Easy wifi radar 1.0.5 has stopped working
easy wifi radar has stopped working it not working plzs help me ant_fernandes12@yahoo.com
Dec 04, 2011 | Makayama Media Easy WiFi Radar
Everytime i try to open the easy wifi finder it says " easy wifi radar 1.0.5 has stopped working"
well run it as administrator and if it does not work than it means that ur window do not support that file cuz i also got the same problem n i decided to get some details to it and i found out my window is window 7 ultimate x64 do not match the file :'(
Aug 20, 2011 | Makayama Media Easy WiFi Radar
Icannot load the driver for Targus acp50us. i am running Windows 7
Do you have the 32-bit version of Windows 7 or the 64-bit version? To identify your version, click Start > Control Panel > System and Security > System. On the line that gives the OS version, if you see x64, then you have the 64-bit OS. If you do not see these extra characters, then you have the 32-bit version.
I suspect you have the x64 version of Windows 7. Targus does not have drivers for Windows 7 x64 for the ACP50US. Targus only supports the ACP45 and the ACP51 docks under the 64-bit OS.
If you have the 32-bit version of Windows 7, download the driver from http://www.targus.com/us/download.aspx?regionid=&sku=acp50us&PageName=&productCategoryId= . This is the Vista (and XP) driver. You may need to use the compatibility mode to get it to work. Right click on the executable file and choose Properties. In the Compatibility tab, choose "Run this program in the compatibility mode". Select Vista or XP in the drop down menu. Then right click on the installer again and choose Run as Administrator.
I hope this helps and I wish that I had better news for you.
Aug 18, 2011 | Targus ACP50US Docking Station
Airlink AWLL3025 usb wifi will not work with Windows 7.Is there a way to fix this?
The drivers are only available through XP, http://www.airlinkplus.com/driver/wireless_download.htm .
It might be possible to use the compatibility mode to force the driver to load. To try this, download the driver and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
However, in the case of a wifi adapter, this doesn't help since you will not be able to share the wifi with the virtual computer. You would be better off finding a different brand of wifi adapter that is win7 compatible. See microsoft.com for the hardware compatibility as you look for models: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
I hope this helps.
Mar 21, 2011 | Airlink AWLH3025 Wireless Adapter
Unable to install Print Shop verison 11 on my Window 7, why?
Print Shop Pro Publisher version 11 was built for Platform OS: Windows 98 / Me / 95. It is an old software which is not for Windows 7(x86 or x64) OS. This is due to software compatibility issues with Windows 7 ie an old software running on a newer OS Platform.
You have to get a newer version which is compatible with Win 7.
Hope it helps.
Mar 11, 2011 | Broderbund Print Shop Pro Publisher 11
Have old printmaster platinum 8.0 tried to download on new comp windows 7 it says something about 16 bits
Printmaster platinum 8.0 is rather an old 16bits software and it is not compatible to your new version Win 7 OS.
You can check software compatibility @ Windows 7 Compatibility Center
Your option is to upgrade to version 18 which is Win 7 compatible.
Hope it helps.
Feb 20, 2011 | Computers & Internet
Is it compatible with windows 7 and if not, what do I have to do to make it compatible?
Check your software Compatibility for windows 7, go to Windows 7 Compatibility Center at Microsoft.
If your version is not compatible you have to check the software site for any newer version which support the Win 7 OS.
You can try the compatibility mode in Win 7, but there is no guarantee it will work.
Hope it helps.
Aug 19, 2010 | Computers & Internet
Is there a version of Canon Easy-WebPrint that is compatible with Internet Explorer 8?
Version 1.0.1 is supposed to be compatible with IE7 and IE8. You can download it here. Select Windows Vista or Windows 7 as the OS to see the files available.
Oct 21, 2009 | Canon Computers & Internet
Computers & Internet Logo
627 people viewed this question
Top Makayama Media Computers & Internet Experts
David Payne
David Payne
Are you a Makayama Media Computer and Internet Expert? Answer questions, earn points and help others
