Question about GE JKP30WMWW 27" Built-in Single Electric Wall Oven with Dual Element Bake & Electronic Oven Control...
Why is the oven stuck with a "Door Locked" error?
Cycling circuit breaker doesn't reset the oven
  • GE Master
  • 473 Answers
Just guessing but did you just use the clean cycle???? During clean, the oven temp gets high enough to trip the door lock safety thermostat. This is to keep owners from trying to open the door when oven is too hot from clean cycle. It sounds like that safety didn't reset to normal when it cooled off and therefore the door is still locked. With door locked you may need to get oven out of the wall and remove top cover to get to the lock system and thermostats. Make sure power is off before doing any of this.
Posted on May 03, 2015
Getting F01 error, even after resetting breaker several times. Also, door lock has been stuck in locked mode.
the fact that you have to keep resetting the breaker should have been enough to tell you that there is a serious short fault in the machine
Take it to an appliance repair shop and have the fault diagnosed and fixed if the quote you get is reasonable
Nov 09, 2015 | Ovens
When trying the clean mode on the oven, it locked up, did not clean, and is not stuck in lock mode. How do I reset it? Turning off curcuit breaker did not help.
Hi Jim, thank you for your post! Once you have the flipped the circuit breaker it is important to wait roughly ten to fifteen minutes. If resetting the power does not correct the issue, you range could be experiencing a communication error with the EOC (electronic oven control), faulty door lock assembly, or could have wiring failure. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Aug 22, 2013 | Electrolux ICON Designer E30SO75ESS Oven
Frigidaire oven door is still locked 7 hours after self-cleaning
Hello - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the range back on. This will clear most false error codes. If error code still displays on panel, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty light switch, door latch or EOC.
Oct 21, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidaire gallery wall oven (2003). We set the self cleaning and then canceled. The door is now locked and the fan is running. I tried to reset breaker and it is still locked. How can I get the...
If tripping and turning the circuit breaker off for about 10 minutes does not work, contact Frigidaire. Sounds like the control board and/or door switch will need replacing.
Aug 07, 2012 | Frigidaire 30 in. Electric Gallery Series...
I used the self-clean for the first time and my oven door is still locked and the display doesn't work at all. Model #YKESS908. What can I do to unlock the oven door? I have checked the circuit...
Hi
You can set the unit on self cleaning and then after 15 minutes stop the cycle, let it cool down for an hour and then open the door. If the issue remains then you'll have to replace the door lock assembly, then you can open the door with a coat hanger by pulling the latch towards you. Hope this helps...please post back for further assistance.
Daniel
Sep 09, 2011 | KitchenAid Ovens
Oven door remains locked after self-cleaning
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 27, 2010 | Thermador SC302T Electric Double Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
What is the reset button for GE Profile JTP18?
For me the solution was in the temperature sensor. The Locked light kept flashing and the door locking mechanism kept cycling when the door was shut or if I just held the oven light switch in the closed door position. After replacing the control panel I still had the same problem. Next I turned off the breaker and then took off the wire covers on the back of the oven and disconnected the temperature sensor. I then checked the continuity of the sensor which was fine. With the sensor still unplugged, I turned the breaker back on and the panel said locked but the locking mechanism was not cycling. With power still on to the oven I connected the temperature sensor. It worked. All I had to do was press the clear button on the touch panel and everything was fine. I turned the breaker back off and reassembled the oven. Hope this helps.
Oct 12, 2008 | GE Profile JTP18 Electric Single Oven
My oven is locked and I have a oven mitt inside how will it come out?
control reading door locked?? or door just stuck in locked position, try turning off hte breaker to the oven for a few secs , reset nad see of the door lock mech reeales itself. if ** you can try to put the unit into a clean cycle, and then 5-10 secs after he door "locks" press hte cancel button. both ways will cycle the door lock/latch assy
Mar 10, 2008 | KitchenAid Architect Series KEBC107KSS...
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
GE JKP30WMWW 27" Built-in Single Electric Wall Oven with Dual Element Bake & Electronic Oven Control... Logo
127 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
