Question about Garden
Why does my mower run slowly?
My mower starts up and runs strong but when i go to turn on the blades it's takes a minute to turn the blades then it turns them really slow.
  • Kenneth Mason May 02, 2015
    It's a zero turn mower and the PTO switch you can hear come on
  • 1,169 Answers
The actual make and model number would of more help but with being ZTR you probably got a V-twin that is running on one cylinder.
Posted on May 02, 2015
    Top Expert:
  • 10,875 Answers
Your spindle bearings are bad,take off the belt and turn each one,the one that doesnt turn freely needs to be replaced
MIlfordPrint
  • 90 Answers
SOURCE: Mower runs but blades aren't turning
You can get help at both of these places:
http://troybilt.custhelp.com/cgi-bin/troybilt.cfg/php/enduser/std_alp.php
http://www.mowersdirect.com/technical-support.php
Posted on Aug 03, 2009
SOURCE: blades wont engage
check the clutch if it engage then check the cable and belt to if it works make sure all the bolts are tight. usually the belts is too loose or if its a clutch drive maybe the clutch doesn't engage or worn out.
Posted on Aug 16, 2009
  • 33 Answers
SOURCE: cub cadet riding mower blade won't turn on
If the click you hear is the electric PTO engaging, then your deck belt is broken or off a pulley some where. Check the belt & then clarify if needed
Posted on Aug 21, 2009
  • 279 Answers
SOURCE: Troy-Bilt Mower is running real slow.
If you can, check the flywheel key. If it is bent but not quite broken, it can cause slow operation. To do that, take the starter off the top of mower. Take off the big nut on the flywheel. Find a nut of the same size and place on the thread you took the nut off, but only a few turns. Hold the flywheel with one hand, lifting a little, and tap the nut with a hammer with the other hand. The flywheel should come off. Look at the key, it holds the flywheel to the shaft. If it is bent or broken, that is the problem. Replace it and go about your day! Good luck...Lee
Posted on Sep 25, 2009
vincob
  • 718 Answers
SOURCE: Blade won't stay engauged
It is very hard to say without knowing model, but if it is a Honda Harmony than I would look towards the the cable that controls the blade engagement. If your model is equipped with a blade engagement lever most likely yours is controlled by a cable also and it only needs to be adjusted correctly. Good luck!
Posted on Oct 22, 2009
My zero turn RZ4623 will start & run fine in idle, but with blades engaged it only runs about 20 to 30 minutes, and quits.
check your battery if it is weak sometimes the PTO takes all the voltage and motor can not run.
Aug 02, 2016 | Husqvarna Garden
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
Worx WG787 lawn mower issue
does the blade spin freely if not bearings going out check make sure blade brake is fully releasing the blade to spin you will probably have to take it in it could be in the activation swicth but you need special tools to check it
Jun 29, 2013 | Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Smells like burning rubber
sounds like a bad bearing take the belt off and see what pulley is hard to turn look for the one with dark marks on it from the belt
May 12, 2012 | Craftsman Garden
Riding mower won't start
take the spark plug out and see if the engine will turn over then, gas will probably come out of the cylinder cause you flooded it when you turned it over after you get the gas out of the cylinder, put the cleaned spark plug back in and it should start
Jun 03, 2010 | Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
