Question about Canon Video Cameras
Why isn't the camera working properly?
I had not used for year. I keep getting the message "task is in progress do not detach from power source". It is plugged into the power source and has a charges battery. It also turns itself on and off. Although it seems to record I can not get access to recorded material. As soon as I put it in play mode I get the task in progress message and the camera shuts down. I am wondering if the internal battery needs replacing or is it a hard drive issue.
SOURCE: Cassette load issue
reel table on the right ( take - up ) if has low tension ? will slow down or stop , giving reinsert error : stretching spring ( inside reel table ) will fix problem , as well as to order and replace reel table .
Posted on Aug 08, 2007
  • 5 Answers
SOURCE: conecting a bullet camera to dv cam
Excuse my ignorance but I am not at all sure what a "bullet" camera is.
I have used a wireless cam (security cam) on a model aircraft and recorded it on my Panny quite well. It is just a matter of connecting up right leads to the right places and this is probably in your manual.
Posted on Jan 01, 2008
I have the same problem.
Posted on Nov 05, 2008
SOURCE: No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Posted on Feb 24, 2009
  • 21 Answers
SOURCE: error message on lcd screen :for infolithium battery only"
Problem connector,DC-IN part no.1-794-637-11
Posted on Sep 23, 2009
Communications error between Windows 8.1 computer and Artisan 835 scanner
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Source : EPSON support
Feb 13, 2014 | Epson Artisan 835 Wireless All-in-One...
My Acer Aspire cd /dvd drive isn't operating properly. I keep getting error message that I have no driver.
many cds/dvds get dirty by fingering on the reading side of them, use tops(ear-cleaners) to remove dirt from lens.
Apr 05, 2012 | Computers & Internet
The battery does not charge, its a new battery.what do i look for?
if its a new battery it could be as simple as it wasn't charged when you purchased it, If it was charged and your mower isn't charging it, the power source to the battery from the mowers motor isn't working properly,, not knowing if its a 12 or 6 volt system you need to check the battery ,, see which one it is,, using a multimetter ( if its 12v ) check the battery after you charge it with an outside source ( battery charger) you would have a reading of 12-12.5 volts on a normal check,, then start the mower, and check the battery as its running,, you should get a reading of 13-13.5 volts minimum, if your not, the alternator or magneto isn't working properly, if you do show the increased voltage at the battery connections, then you need to clean the contacts since the charge isn't reaching the actual battery
May 24, 2011 | Garden
Even with absolutely fresh batteries properly installed, I keep getting a "change the batteries" message, and then the camera shuts down. It worked fine for two years!
Peter,
Try using a Q-tip and some alcohol to clean the contacts inside the battery housing of the camera - it's possible there's enough build up to prevent a clean connection.
Thank you.
Mar 22, 2011 | Canon PowerShot A560 Digital Camera
Coolpix 995 CF Card error
My Nikon 995 began having trouble communicating with the CF card. At first it was intermittent then later there was nothing. After a couple of years of non-use, I decided to open it up to see if there was anything obvious. If I destroyed the camera in the process, no big loss. All the card slot pins were there and non were bent or coroded. Removing the drive, I could see under a microscope about half the pins on one side solder connections had broken. I assume from the repeated insertion and extraction of the card. (I use a card r/w drive in my pc instead of an interface cable to the camera). After I reflowed the pin solder connections and re-assembled the camera, all is good again.
You should know the disassembly/assembly of the camera is complex, and tedious. The connector pins are very small. I repaired the pin solder connections using a small high quality soldering iron while looking through a microscope. Witthout the scope, I couldn't even tell the connections were bad much less be able to repair them.
Jun 28, 2009 | Nikon Coolpix 990 Digital Camera
Router will not power up
I wrote a long response to your question, which apparantly has been lost in the web somewhere.
Try to make sure the detachable power cord is properly connected, and twisted 1/4 turn clockwise to lock in place.
Make sure the toggle switch is working freely.
Make sure the collet lock or spindle lock is not engaged.
If that doesn't help, please write back and I'll try to re write a troubleshooting guide for you.
I can't believe it didn't post properly.
Anyway, good luck!
Mar 21, 2009 | Dewalt DW616m 1 3/4 Maximum Motor HP...
Printer will not install with cd
open the task manager and close everything except "systray" and "explorer", then try again.
Presuming you are running windows.
Feb 20, 2009 | Sony Computers & Internet
Error message "power surge on hub" when attempting to upload from N C 5200
Hi, are you using a USB hub or attaching directly to the computer USB port?
  1. If you are using a USB hub, which is then connected to your computer ... you either need to
    1. Plug the camera directly in to the computer so that the computer supplies the USB with more power to the camera.
    2. If the USB hub has a power plug/adapter, use it so the USB hub gets more power to handle the task.
    3. Buy a different USB hub that has a power adapter so enough juice can be supplied to the tasks that USB is asking to do.
  2. Some USBs on the computer aren't giving enough power, you may have a bad USB port, try another one.
  3. Use a Card Reader, which is much faster to download pictures than from the camera.
Reason: some times, the USB task is asking for a lot more power than is being supplied through the current USB path. You have to either add power through an adapter or plug directly in to a power source (like the computer directly, or a reader that doesn't require as much power to operate it).
This should help, if so, please mark as FixYa!
ThankYa!
Dec 01, 2007 | Nikon Coolpix 5200 Digital Camera
Re-attach the power source followed by Reinsert Cassette
Hai Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism. Raghavendra, M/s.prathiksha Electronics
Jan 25, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Video Cameras Logo
70 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
