Question about HP Photosmart C7180 All-In-One InkJet Printer
The black ink is not working how do i fix ? - HP Photosmart C7180 All-In-One InkJet Printer
  • AaenergyPsychic MoneytreesCarracino
    my hp c7180 it copies in color but when i press black it comes out blank and the color is a little off
  • HP Master
  • 5,631 Answers
It might be empty, clogged or damaged.. Take it out and go to some ink filler service where they have an ultrasound unclogger ; they can verify status of the head, refill it or rate it, if that's the problem..
If problem is clogging, might be too late because sometimes if you keep your printer head in use, might not be possible to repair it.
If it is damaged, no way, you must buy a new one.
Posted on May 02, 2015
Testimonial: "i put in a new cartridge"
My desk jet 3320 printer do not print black
Are you sure there is enough level on the black ink cartridge.. if does try to do "print head clean up" if doesn't fix the problem consider to replace the black ink cartridge
Aug 31, 2012 | HP DeskJet 3320 InkJet Printer
We refilled our own black ink cartridge this week. The printer worked fine for a while, then all of a sudden the computer says that the black ink is empty and won't print anything. I checked the black ink...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Mar 29, 2011 | Canon PIXMA MP495 InkJet Printer
The black ink print is very very faint
Indicates that the printer is using only color ink to create a black color. Check printer settings to see if you can set it to use only black cartridge. Also try printing with only the black cartridge inside if the printer permits, this way you can be sure if the black print head is faulty.
Jul 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Have black ink but but not color will it work
You have to insert color cart or it will not work
Feb 15, 2009 | HP PhotoSmart 1115 InkJet Printer
Ink
You can use the kodak interactive site to fix this issue, just follow the steps there to take care of this problem
Go to www.kodak.com/go/itg missing colors for sub class
Nov 02, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Black ink cartridge
i called the same number as mshanklin and had the same offer of print head and replacement cartridges. they better work! :)
Sep 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
924 says that black ink cartridge not installed
Hmmm....that sounds to be an issue with the ink cartridges...
You might be using ink cartridges purchased other than Dell or Staples...since these are the two who sell Dell Ink.
If thats not true, then take out both the cartridges in the printer.
Lets isolate the issue
1. Try only Black cartridge on Color slot(right). If you get Install both ink cartridges error, then its an issue with the Black ink cartridges and if you get message that install Black ink cartridge then its an issue with the prrinter.
2. Now install only color cartridge on Black cartridges slot(left), If you get color cartridge missing then its an issue with the Black cartridges which you are using and if you get install both ink cartridges then its an issue with the black slot on printer.
3. If issue found to be with Black ink cartridge then wipe the Nozzles(bottom) of the ink cartridge with lint free cotton cloth from back to front 5-6 times.
4. Also try replacing the ink cartridges purchased only from Dell or from Staples. Purchased from somewhere else or refilled might not work.
5. If issue found to be with printer, then i would suggest you to purchase new printer then.
Hope this fix the issue
Aug 14, 2008 | Dell 924 All-in-One InkJet Printer
Colored Ink problem
Make sure you are using the correct cartridges for the Z35. They should be #26 (color) and #16 (black).
Make sure the contacts are clean where the cartridge connects to the printer electrically. A little alcohol wipe is good for this. Clean contacts on both the cartridge and the carrier in the printer.
Nov 19, 2007 | Lexmark Color Z35 InkJet
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
HP Photosmart C7180 All-In-One InkJet Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
