How to solve printing shading - Office Equipment & Supplies
First few prints shaded. Later prints become good.?
Remove the toner cartridge and turn it upside down and give it a few taps with the heel of your hand. Tip it left and tap and right and tap. Now turn it the right way up and give it several taps. This should break up and redistribute the toner. Now install it back and run a test page.
Oct 04, 2015 | Samsung Office Equipment & Supplies
How to solve printing was double shaded
If you have one of those deskjet printers with two heads: black and color, might be that heads us unaligned.
Look ar printe's utilities.
In tnis case your printer has an application to align the two heads avoiding this "double shaded" effect.
May 02, 2015 | Office Equipment & Supplies
Images are repeating in printing, like shade.
The problem is in your print cart. or fuser, take out your print cart. (toner) look at the drum, if clean its the fuser. -Carl
Apr 21, 2014 | Konica Minolta Office Equipment & Supplies
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
HP Photosmart c4480, prints black where gray shades exist
try cleaning the printhead your printer seem to have an image quality issue
Sep 23, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Shades on Prints
run the alignment program
Nov 18, 2008 | Xerox DocuColor 12 Printer
Very Light Print
What you need to do is adjust shading. That recalabrates the scanner. To enter the machine into the tech mode you press " menu, # 1934" then you will be in the tech mode, a T should appear on the machine screen. You then go to machine setup and maintenance, then scroll to adjust shading or just shading, depending on how your specific firmware states it.
Then place 5 sheets of white paper on the glass, 5 pieces of paper think not spread out, then press start, if it askes you DO you want to asjust press start and let it run through the setup.
Once you have cleaned the scanner you really need to adjust teh shading. A better way to say it would be scanner calabration.
Oct 17, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
HP 1018 printing problem
hi,
this could happen due to a problem in the cartridge, try printing with a different one.
Apr 01, 2008 | HP LaserJet 1020 Printer
jasbo
jasbo
