Why is it stuck between cycles?
Does not work at all. Lights are on
  • tom cassidy
    tom cassidy May 03, 2015
    Hi Gerda Hattingh, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Gerda Hattingh
    Gerda Hattingh May 04, 2015
    Hi -fault was blocked filter, located on bottom of machine behind panel. Back in working order!
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check door or lid lock
Posted on May 03, 2015
  • Gerda Hattingh
    Hi, this model has a tiny filter located at the bottom, behind a panel which clips off. We cleaned that, and machine works!
Why won't it run
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic board.91d0c2b1-1baa-49b9-9f99-f6a86f3b29df.jpg
Sep 29, 2013 | Frigidaire Gallery FGBD2451KB Full Console...
Kenmore underwater dishwasher 665 series stopped running mid cycle - all lights went out and will not start again. No lights will go on.
see the causes and fix it:God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Jul 21, 2012 | Dishwashers
Rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Oct 15, 2009 | Washing Machines
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Lights are on controls on not cooling
hi thanks for the question Your fridge is stuck in defrost cycle replace defrost timer. THanks for the Question The appliance doc
Sep 12, 2008 | GE PFS22SBSSS Stainless Steel French Door...
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Powerpoint dishwasher TW26
cannot change the program low salt and low rince lights on but no lights on the cycle indicator lights.
May 02, 2008 | Dishwashers
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
